Trying to understand navigation using a rotary encoder and a tile view
the simulator
understand how the navigation is meant to work and use it that way
I have created a tile view with several tiles. Each tile has a button on it.
I want to be able to rotate to a tile, press enter (on the encoder), enter the tile and give focus to the button. Rotate the encoder to change the value of the button and then long press to give focus back to the tile.
I have most of the code implemented to do this but i feel i maybe overthinking my solution
So I have a couple of questions
1: Is it expected that you can have an object in focus but not showing on the display? E.g. when a tile is given focus, I manually move it into the visible part of the display using the on_Focus event from the tileview.
2: When I select a tile by pressing enter, i remove all the objects from my group and add only the objects in the focused tile to the group, when i leave the tile, i remove all the objects from the group and then add just the tiles to the group. Is this the correct process?
3: When using a rotary encode for navigation, i can switch between navigation and edit mode by calling the lv_group_set_editing function. Is there any time when littleVGL does this automatically?
Thanks
Stuart
