Sorry but I have been sidetracked by other tasks recently. I’ll return to the screen calibration soon now.
The OpenUI user interface management system (UIMS) was the first product from Open Software Associates, which was the very first dot-com-dot-au, of which I was inventor and co-founder in 1990. It used a virtual widget set in the basic toolkit (called the Equaliser) that mapped each widget to its equivalent - on OSF/Motif, on Windows (16 bit and NT), OS/X, MacOS and even on character terminals. The Equaliser widgets were in an abstract hierarchy completely defined by property values, so not just the layout definitions, but the entire runtime state of a UI could be captured by enumerating the hierarchy and saving all non-default values for the properties. The exact same UI could be reconstructed by constructing the same hierarchy and setting the same values, right down to focus widget and cursor position. The reconstruction could even be on a different GUI environment from the one it was captured in. So I think you’ll see why I prefer property values that have been set, to be able to be retrieved again!
The OpenUI Equaliser was deeply integrated into an O-O compiler-interpreter language (very like Java in design, but some years prior) that used message-passing to create point-to-point and publish-subscribe rich application messages to activate everything. Messages naturally “bubbled” up through the hierarchy until most of them would cross the network to a back-end server application, so everything from a mouse-motion to a “list all matching records” message was integrated into a single simple framework.
The largest application written in OPL (the OpenUI Programming Language) was the IDE, which directly manipulated live widgets in design mode. The language had full tracing and single-step or breakpoint debugging. The output of the OPL compiler was machine-independent “dictionary” files that were shipped and updated transparently to the client side for display, regardless of the target display hardware. The only proviso was that the vector-based graphics were not attempted on character-mode terminals! Client companies however were known to have ported large applications (e.g. 600 screens in an IT help desk for a Telco) from Windows NT to MacOS in a single morning - with a result that was ready for production… much to the amazement of everyone including ourselves (even though that’s exactly what the product was designed to do). OpenUI was used to deliver world-first Internet share-trading and online banking in some of Europe’s largest banks, and was also used to build the new trading system deployed at NASDAQ after they combined with the London Stock Exchange to form the first intercontinental linkage of capital markets.
All in all, by 1992, OpenUI had delivered everything that Java was still promising in 2000, but did not actually deliver until almost 2010. Sadly the business was forced to pivot and the product was lost.
Now, back to LVGL, and what this means. I would like to build a markup language for LVGL, akin to OPL, or in your terms, to a merger of the capabilities of HTML, CSS and JS - but in a single unified language. To achieve this, I will need to define all the attributes of all objects, and ensure that the values are stable - when set, they stay set! Any dynamic computation is internal, applying to non-settable (perhaps even invisible?) internal attributes.
I have a syntax to propose for this markup language, but before I show you that, I’d like to hear your feedback so far.
