I’m having difficulty to get a lv_obj that is in the top_layer, to render properly every time it’s flag changes from hidden to visible.
Environment: ESP-IDF, ESP32S3, VSCodeInsiders, lvgl 8.3.0 via idf_components.yml
The object is set up as follows.
* @brief Modal trays container
trays_cont = lv_obj_create(lv_layer_top());
lv_obj_add_flag(trays_cont, LV_OBJ_FLAG_HIDDEN); /* set invisible till required.*/
lv_obj_set_size(trays_cont, LV_HOR_RES, LV_VER_RES);
lv_obj_set_scrollbar_mode(trays_cont, LV_SCROLLBAR_MODE_OFF);
lv_obj_t *trays_label = lv_label_create(trays_cont);
lv_label_set_text(trays_label, "Enter Nr of Trays");
lv_obj_align(trays_label, LV_ALIGN_TOP_MID, 0, 0);
/*trays_ta */
trays_ta = lv_textarea_create(trays_cont);
lv_textarea_set_one_line(trays_ta, true);
lv_textarea_set_text(trays_ta, itoa(packhouse_scale_data->ph_scale_last_units_packaging, trays, 10));
lv_obj_align_to(trays_ta, trays_label, LV_ALIGN_OUT_BOTTOM_MID, 0, 0);
/*bmatrix */
lv_obj_t *bmatrix = lv_btnmatrix_create(trays_cont);
lv_btnmatrix_set_map(bmatrix, btnm_map);
lv_obj_set_size(bmatrix, 230, 230);
lv_obj_align_to(bmatrix, trays_ta, LV_ALIGN_OUT_BOTTOM_MID, 0, 0);
lv_btnmatrix_set_btn_ctrl(bmatrix, 12, LV_BTNMATRIX_CTRL_CHECKED);
lv_obj_add_event_cb(bmatrix, mb_event_cb, LV_EVENT_ALL, NULL);
So when I have the need for this modal keypad (top layer screen), I set the flag to invisible.
lv_obj_clear_flag(trays_cont, LV_OBJ_FLAG_HIDDEN); /* make visible now */
50% of the time it renders properly, with the entire screen taken up with the modal screen.
Other times, it is only partially rendered, and the main screen still visible in the background, with only part of the keypad rendered. It’s as if LVGL doesn’t finish rendering the entire screen.
It also allows you to scroll the top layer screen in spite of the flag being set for no scroll, with this line of code:
I will appreciate any advice on how to fix this reliably.
Thx
