The screen is rotated to 90 and the cursor in the input box is not working
Using the screen rotation function lv_disp_set_rotation(NULL, LV_DISP_ROT_90), rotate the screen to 90. The cursor of the input box control appears with a black stripe (the default is portrait, rotated to landscape), and when you animate to return to the previous screen, it also appears with a black stripe.
君正x2000
v8.3.4
Want to achieve screen rotation, control normal display.
1.At first, I thought it was full_cb, so I printed the refresh coordinates, but it turned out that full_cb was called and x returned negative coordinates.
2.I’ll start with the layer set to lv_typer_top(), invalid.
3.I set the default screen orientation to 90 when I started disp_init, and the result was the same.
4.Currently I can only mask the relevant coordinates, which causes the cursor to refresh only 1/2.
void lv_port_disp_init(void)
     * Initialize your display
    fbdev_init();
        static lv_disp_draw_buf_t draw_buf_dsc_3;
    static lv_color_t buf_3_1[MY_DISP_HOR_RES * MY_DISP_VER_RES];            /*A screen sized buffer*/
    static lv_color_t buf_3_2[MY_DISP_HOR_RES * MY_DISP_VER_RES];            /*Another screen sized buffer*/
    lv_disp_draw_buf_init(&draw_buf_dsc_3, buf_3_1, buf_3_2,
                          MY_DISP_VER_RES * MY_DISP_VER_RES);   /*Initialize the display buffer*/
     * Register the display in LVGL
    static lv_disp_drv_t disp_drv;                         /*Descriptor of a display driver*/
    lv_disp_drv_init(&disp_drv);                    /*Basic initialization*/
    disp_drv.hor_res = MY_DISP_HOR_RES;
    disp_drv.ver_res = MY_DISP_VER_RES;
    /*Set a display buffer*/
    disp_drv.draw_buf = &draw_buf_dsc_3;
    /*Rotate*/
    disp_drv.sw_rotate = 1;
    disp_drv.rotated = LV_DISP_ROT_NONE;
This is the original code that had the truncation in it, and I tried to remove the screen truncation, but obviously negative values crash.(Here I’ve added two printf functions)
void fbdev_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
    if(fbp == NULL ||
            area->x2 < 0 ||
            area->y2 < 0 ||
            area->x1 > (int32_t)vinfo.xres - 1 ||
            area->y1 > (int32_t)vinfo.yres - 1) {
        lv_disp_flush_ready(drv);
        return;
    printf("x1 = %d, y1 = %d\nx2 = %d, y2 = %d\n", area->x1, area->y1, area->x2, area->y2);
    int32_t act_x2 = area->x2 > (int32_t)vinfo.xres - 1 ? (int32_t)vinfo.xres - 1 : area->x2;
    int32_t act_y2 = area->y2 > (int32_t)vinfo.yres - 1 ? (int32_t)vinfo.yres - 1 : area->y2;
    printf("x1 = %d, y1 = %d\nx2 = %d, y2 = %d\n", act_x1, act_y1, act_x2, act_y2);
    lv_coord_t w = (act_x2 - act_x1 + 1);
    long int location = 0;
    /*32 or 24 bit per pixel*/
    if(vinfo.bits_per_pixel == 32 || vinfo.bits_per_pixel == 24) {
        uint32_t * fbp32 = (uint32_t *)fbp;
        int32_t y;
        for(y = act_y1; y <= act_y2; y++) {
            location = (act_x1 + vinfo.xoffset) + (y + vinfo.yoffset) * finfo.line_length / 4;
            memcpy(&fbp32[location], (uint32_t *)color_p, (act_x2 - act_x1 + 1) * 4);
            color_p += w;
