Further to my post on the old forum(link below), I have located another typedef which needs to be changed from int16_t to int32_t at line 39 of lv_anim.h. For the roller to function correctly with animation enabled…
/*Type of the animated value*/
//typedef int16_t lv_anim_value_t;
typedef int32_t lv_anim_value_t;
https://forum.lvgl.io/viewtopic.php?f=15&t=194
Kind Regards,
Pete
This was originally changed to int16_t
here: https://github.com/littlevgl/lvgl/issues/1049
Hi @embeddedt,
I have just read that post and understand the problem when used with a 16-bit processor, but if you are using lv_coord_t
defined as int32_t
in ‘extreme cases’ like mine… as we discussed here…
Then for the animations not to suffer overflow we also need to define the lv_anim_value_t
to be signed 32-bits also.
Kind Regards,
Pete
Should we just typedef lv_anim_value_t
to be an lv_coord_t
then, because they are usually used together?
Hi @embeddedt that sounds like a very sensible solution.
Kind Regards,
Pete
Hi @embeddedt,
Can I propose that line 39 of lv_anim.h be changed to:
typedef lv_coord_t lv_anim_value_t;
Then this issue is resolved.
Kind Regards,
Pete
We need to check with @kisvegabor, but I don’t think that will be a problem.
As animations can animate any values I think it would be confusing to use the lv_coord_t
as type. What about adding typedef int16_t lv_anim_value_t;
to lv_conf.h?
to lv_conf.h?
I respectfully disagree. When lv_anim_value_t
is written in code it doesn’t mention lv_coord_t
at all.
Your suggestion would work, but the problem with that is that there are then two typedefs for related types. In general, I think it’s better to consolidate the typedef
s.
This seems to be leading back to the discussions we had about lv_int_t
@embeddedt
Sorry, I didn’t notice you comment. Please ping me if don’t answer for so long.
s.
Okay, let’s use typedef lv_coord_t lv_anim_value_t;
. I added it here
