Hi everyone,
I’ve been testing a workflow around a question I often see in real HMI projects:
What happens after the UI is designed in Figma?
Getting screens into LVGL is one part of the problem. The harder part is turning a design into something that actually works well on embedded hardware:
- identifying screens, states and interactions
- separating visual elements from application logic
- checking resolution, memory and rendering requirements
- choosing an appropriate MCU / MPU / SoM
- connecting the UI to real device functions
- finally running and testing it on physical hardware
I’ve built an experimental workflow to test this path:
Figma / UI design
→ requirement & interaction analysis
→ structured HMI definition
→ LVGL implementation
→ embedded hardware
I’ve already run several internal tests on real boards, and the next step is more interesting:
I’d like to test it with real HMI designs from other developers.
If you have:
- a Figma HMI design
- an existing GUI that you want to move to LVGL
- a sketch or UI concept
- or a prototype currently running on a development board
I’m happy to take a look.
For a few suitable examples, I’d like to see how far we can take them toward a working hardware proof of concept, and document what works and what breaks along the way.
I’m especially interested in industrial controls, appliances, instruments, robotics and other embedded products where the UI eventually needs to interact with real hardware.
This is not meant to be another UI editor comparison.
The experiment is really about the gap between:
“the UI looks right”
and
“the product actually works on embedded hardware.”
If anyone has a UI that would make a good test case, feel free to share a screenshot or describe the target hardware here.
I’ll post the results and lessons from each test as the workflow develops.
