Hi, i am trying to map a potentiometer value from port A0 to a LVGL gauge however i am experiencing the error:
‘invalid conversion from ‘void ()(lv_task_t) {aka void ()(_lv_task_t)}’ to ‘lv_task_cb_t {aka void ()(_lv_task_t)}’ [-fpermissive]’
Arduino IDE/ Arduino DUE
latest (7.8.1)
A smooth gauge that shows the current value of the Potentiometer
I have tried copying code from LVGL academy but i still get the same error
#include <lvgl.h>
#include <lv_examples.h>
#include <UTFT.h>
#include <UTouch.h>
static lv_color_t buf[LV_HOR_RES_MAX * 54];
const byte potPinOn = A0;
long triggerInterval = 0;
lv_obj_t* gauge;
static uint32_t user_data = 10;
UTFT myGLCD(SSD1963_480272, 38, 39, 40, 41); //(byte model, int RS, int WR, int CS, int RST, int SER)
UTouch myTouch( 43, 42, 44, 45, 46); //byte tclk, byte tcs, byte din, byte dout, byte irq
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * dsc)
Serial.printf("%s@%d->%s\r\n", file, line, dsc);
Serial.flush();
/* Display flushing */
myGLCD.drawBitmap(area->x1, area->y1, w , h, (bitmapdatatype)color_p, 1);
lv_disp_flush_ready(disp);
/*Read the touchpad*/
bool my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
uint16_t touchX, touchY;
myTouch.read();
int x = myTouch.getX();
int y = myTouch.getY();
bool touched = false;
if ((x != -1) and (y != -1)) touched = true;
if (!touched)
data->point.x = x;
data->point.y = y;
return false; /*Return `false` because we are not buffering and no more data to read*/
void setup()
#if USE_LV_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
myGLCD.InitLCD();
pinMode(8, OUTPUT); //backlight
digitalWrite(8, HIGH);//on
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
void loop()
// myGLCD.fillScr(0xff, 0x00, 0x00);
//myGLCD.fillScr(0x00, 0xff, 0x00);
triggerInterval = analogRead(potPinOn);
triggerInterval = map(triggerInterval, 0, 1023, 0, 1000);
delay(5);
void task_cb(lv_task_t task)
Serial.print("called");
void task(void)
lv_task_t* task = lv_task_create(task_cb, 100, LV_TASK_PRIO_MID, NULL);
lv_obj_t* gauge = lv_gauge_create(lv_scr_act(), NULL);
lv_obj_t* label = lv_label_create(gauge, NULL);
lv_obj_set_pos(gauge, 20, 20);
lv_obj_set_size(gauge, 250, 250);
lv_gauge_set_range(gauge, 0, 1000);
lv_gauge_set_value(gauge, NULL, triggerInterval);
lv_label_set_text(label, "POT");
lv_obj_align(label, gauge, LV_ALIGN_CENTER, 0, 50);
