Hi All,
I tried to register on Squareline Vision, but after verification, I can’t seem to login and I’ve also tried to forgot password(which worked) but still doesn’t allow me to login.
@SquareLineStudio
Thank you!
Hi All,
@SquareLineStudio
Thank you!
Thanks for reaching out!
We checked your account based on your email address and found a verified registration, but the email on that account is slightly different: it uses a dot in the address (so it’s not exactly the same as the one you’re trying to log in with).
Please try one of the following:
After that, the login should work normally.
thank you! that worked!. it probably got stripped because if I didn’t use the one without dot I probably wont receive the verification email from that.
Thank you! still exploring this one around, I just don’t see the chart which I was using in SquarelineStudio
Great to hear it worked!
About the chart you used in SquareLine Studio: at the moment the Chart widget isn’t available in SquareLine Vision yet. We’re working on bringing it over, and it’s planned for an upcoming release (most likely the next version).
Please note that LVGL has no connection to SquareStudio other than SquareLine is using LVGL for free. We have
Our relationship went really deep… In light of these, please use forum.squareline.io for questions related to them.
Thank you, Gábor, for your comments. If you have any questions or issues with SquareLine Studio or Vision, please use the dedicated channels instead: the SquareLine Studio and Vision contact forms, the Studio forum page, and the Vision Discord channel.
