I have two graphics where I have used gradients - I am getting suspected memory issues
when the underlying gradient graphics are either being drawn or been drawn.
The screen locks up when this happens.
Processor is STM32H743
V8.1.1 (I cant upgrade to a later version as this is on a existing product, this is a minor update project)
I would like to find out what is going on so I can make the gradients work
Debugging using Crossworks compiler for ST
I do have the code running in a visual studio simulator, but it works with no issue,
This is the code for the first graphic, its a roller widget with a gradient
This declaration is static lv_obj_t* TemperatureSelectRoller = lv_roller_create(ParentTemperatureContainer);
lv_obj_set_size(TemperatureSelectRoller, 220, 220);
lv_obj_set_pos(TemperatureSelectRoller, (CONTAINER_WIDTH / 2) - 110, (CONTAINER_HEIGHT / 2) - 110);
lv_obj_set_style_text_font(TemperatureSelectRoller, font_large_temp, LV_PART_SELECTED);
lv_obj_set_style_text_align(TemperatureSelectRoller, LV_TEXT_ALIGN_CENTER, LV_PART_SELECTED);
lv_obj_set_style_text_font(TemperatureSelectRoller, font_title, 0);
lv_roller_set_options(TemperatureSelectRoller, TargetTemperatureSelectOptions, LV_ROLLER_MODE_NORMAL);
lv_roller_set_visible_row_count(TemperatureSelectRoller, 4);
lv_obj_set_style_bg_color(TemperatureSelectRoller, lv_color_hex(COLOUR_WARM), 0);
lv_obj_set_style_bg_color(TemperatureSelectRoller, lv_color_hex(ROLLER_BAR_CENTRE_COLOUR), LV_PART_SELECTED);
lv_obj_set_style_border_color(TemperatureSelectRoller, lv_color_hex(SETTINGS_BTN_COLOUR), 0);
lv_obj_set_style_bg_opa(TemperatureSelectRoller, LV_OPA_COVER, 0);
lv_obj_set_style_bg_opa(TemperatureSelectRoller, LV_OPA_80, LV_PART_SELECTED);
lv_obj_set_style_bg_grad_color(TemperatureSelectRoller, lv_color_hex(COLOUR_COLD), 0);
lv_obj_set_style_bg_grad_dir(TemperatureSelectRoller, LV_GRAD_DIR_VER, 0);
lv_obj_set_style_radius(TemperatureSelectRoller, LV_RADIUS_CIRCLE, 0);
lv_obj_set_style_radius(TemperatureSelectRoller, 20, LV_PART_SELECTED);
lv_roller_set_selected(TemperatureSelectRoller, 10, LV_ANIM_ON);
The second graphic is:-
PowerLevelSelect.slider is a static declaration
lv_obj_set_pos(PowerLevelSelect.slider, 86, 16);
lv_obj_set_size(PowerLevelSelect.slider, 740, 24);
lv_obj_set_style_bg_color(PowerLevelSelect.slider, lv_color_hex(0xACABED), 0);
lv_obj_set_style_bg_color(PowerLevelSelect.slider, lv_color_hex(0xFFFFFF), LV_PART_KNOB);
lv_obj_set_style_bg_opa(PowerLevelSelect.slider, LV_OPA_TRANSP, LV_PART_INDICATOR);
lv_obj_set_style_bg_opa(PowerLevelSelect.slider, LV_OPA_COVER, 0);
lv_obj_set_style_bg_grad_color(PowerLevelSelect.slider, lv_color_hex(0x3B24C6), 0);
lv_obj_set_style_radius(PowerLevelSelect.slider, 16, 0);
lv_obj_set_style_bg_grad_dir(PowerLevelSelect.slider, LV_GRAD_DIR_HOR, 0);
When the second gradient graphic has been drawn,
the below images are where the software is hanging up,
These were two different runs… both hang in similar but different places
