SOLVED How to make lv_tabview work with a simple ENCODER input-driver
any idea, how to make lv_tabview work with an ENCODER input-driver ?
I am trying to use a simple ENCODER with LEFT, RIGHT, ENTER for steering the tab-view. Moving from one tab to another… and moving within the tab.
ESP32 based M5Stack Core with latest ESP-IDF
8.2 LVGL
ENCODER working fine for groups with buttons, etc.
For tabviews two alternatives have been tested:
a) adding the tabview to the standard group
b) adding the tabs of the tabview to the standard group
For both see next section.
    lv_group_t *lvGroup = lv_group_create();
    lv_group_set_default(lvGroup);
    // Create a Tab view object
    lv_obj_t *tabview;
    tabview = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, 20);
    // Add 3 tabs (the tabs are page (lv_page) and can be scrolled
    lv_obj_t *tabAbout = lv_tabview_add_tab(tabview, "About");
    lv_obj_t *tabParing = lv_tabview_add_tab(tabview, "Pairing");
    lv_obj_t *tabStats = lv_tabview_add_tab(tabview, "Stats");
    // Add content to the tabs
    lv_obj_t *label = lv_label_create(tabAbout);
    lv_label_set_text(label, "SmartieNG");
    label = lv_label_create(tabParing);
    lv_label_set_text(label, "Paring");
    const char *data = "Hello world";
    // Create a 100x100 QR code
    lv_obj_t *qr = lv_qrcode_create(tabParing, 100, lv_color_hex3(0x33f), lv_color_hex3(0xeef));
    // lv_scr_act()
    // Set data
    lv_qrcode_update(qr, data, strlen(data));
    label = lv_label_create(tabStats);
    lv_label_set_text(label, "Stats");
    /* THIS is a) */
    lv_group_add_obj(lvGroup, tabview);
    /* THIS is b)
    lv_group_add_obj(lvGroup, tabAbout);
    lv_group_add_obj(lvGroup, tabParing);
    lv_group_add_obj(lvGroup, tabStats);
    lv_obj_scroll_to_view_recursive(label, LV_ANIM_ON);
none
That was an easy one, neither a) nor b) is needed…
BUT lv_indev_set_group(indev, lvGroup); was missing…
And then everything works perfectly fine.
