In my project, the size of the ROM is relatively small (only 128k).
So I turned off all unnecessary components, including LV_USE_GROUP.
Then I found that LV_SIGNAL_CONTROL and LV_SIGNAL_GET_EDITABLE are still handled in signal_cb of many controls.
Cortex-M3 with 128k rom, 64k ram
What do you experience?
If these codes are not blocked, it will increase unnecessary size
What do you expect?
LV_USE_GROUP can turn off all GROUP-related singles, or provide a new macro to do this
static lv_res_t lv_btn_signal(lv_obj_t * btn, lv_signal_t sign, void * param)
lv_res_t res;
/* Include the ancient signal function */
res = ancestor_signal(btn, sign, param);
if(res != LV_RES_OK) return res;
if(sign == LV_SIGNAL_GET_TYPE) return lv_obj_handle_get_type_signal(param, LV_OBJX_NAME);
bool tgl = lv_btn_get_checkable(btn);
if(sign == LV_SIGNAL_RELEASED) {
/*If not dragged and it was not long press action then
*change state and run the action*/
if(lv_indev_is_dragging(param) == false && tgl) {
uint32_t toggled = 0;
if(lv_obj_get_state(btn, LV_BTN_PART_MAIN) & LV_STATE_CHECKED) {
lv_btn_set_state(btn, LV_BTN_STATE_RELEASED);
toggled = 0;
else {
lv_btn_set_state(btn, LV_BTN_STATE_CHECKED_RELEASED);
toggled = 1;
res = lv_event_send(btn, LV_EVENT_VALUE_CHANGED, &toggled);
else if(sign == LV_SIGNAL_CONTROL) {
char c = *((char *)param);
if(c == LV_KEY_RIGHT || c == LV_KEY_UP) {
if(lv_btn_get_checkable(btn)) {
uint32_t state = 1;
res = lv_event_send(btn, LV_EVENT_VALUE_CHANGED, &state);
else if(c == LV_KEY_LEFT || c == LV_KEY_DOWN) {
uint32_t state = 0;
return res;
NULL
