I am trying to create a UI using a Adafruit Feather RP2040 paired with a Adafruit Featherwing TFT. I have the following widgets:
screen:
tileview
tile1
tile2
With those widgets, the UI works fine. However, as soon as I add an object with lv_obj_t *grid = lv_obj_create(tile1) it seems that the RP crashes (I no longer get output on the serial console, I can’t open the com port any more, and the screen is not responsive).
For reference, here is the actual code that I am using:
lv_style_t style;
lv_style_init(&style);
lv_style_set_radius(&style, 5);
lv_style_set_outline_width(&style, 2);
lv_style_set_outline_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_outline_pad(&style, 0);
// create the tile view
lv_obj_t *tileview = lv_tileview_create(lv_screen_active());
lv_obj_set_size(tileview, TFT_W - 20, TFT_H - 20);
//lv_obj_set_scrollbar_mode(tileview, LV_SCROLLBAR_MODE_OFF);
lv_obj_t *tile1 = lv_tileview_add_tile(tileview, 0, 0, LV_DIR_RIGHT);
lv_obj_add_style(tile1, &style, 0);
lv_obj_t *tile2 = lv_tileview_add_tile(tileview, 1, 0, LV_DIR_LEFT);
lv_obj_t *grid = lv_obj_create(tile1);
Can someone help me understand what is happening?
Thank you.
reso
October 25, 2025, 8:42am
2
Try set your style as static
static lv_style_t style
Thank you. That got me further but I fear I am missing something fundamental. It now crashes using this code:
const int32_t col_dsc[] = { 50, 50, 50, 50, LV_GRID_TEMPLATE_LAST};
const int32_t row_dsc[] = { LV_GRID_FR(1), 50, 50, LV_GRID_TEMPLATE_LAST };
static lv_style_t style;
lv_obj_set_size(tileview, TFT_W, TFT_H);
lv_obj_set_grid_dsc_array(grid, col_dsc, row_dsc);
lv_obj_set_size(grid, TFT_W - 30, TFT_H - 30);
lv_obj_center(grid);
lv_obj_set_layout(grid, LV_LAYOUT_GRID);
lv_obj_add_style(grid, &style, 0);
lv_obj_t *label = lv_label_create(grid);
If I remove the last line from the code above, it works. But when I add it back in, the RP starts crashing again.
Seems you are out of stack. Check lvconf memory size and setup.
reso
October 26, 2025, 10:45am
5
Im not familiar with RP2040 debug capabilities, but I would suggest to enable LVGLs log print feature, and print trace level info - it will help you troubleshoot some of these issues
I tried setting the stack size to:
#define LV_TASK_STACK_SIZE (128U * 1024U)
But that did nothing. It still crashes. I then tried
#define LV_MEM_SIZE (128U * 1024U) /*[bytes]*/
#define LV_TASK_STACK_SIZE (32U * 1024U)
still no-go. Still crashing.
