WT32-SC01, so more or less a ESP32
v 7.10
I want to rotate widgets, e.g. I want to rotate a slider widget by 90 degrees, but I wasn’t able to find anything related to this. Is this even possible with lvgl?
This would be indeed an option if I only want to change from horizontally to vertically, but in my case I actually would like to display the sliders in various rotations by different degrees, basically as shown in this quick mock-up.
Unfortunately this is not very easy to pull off, as LVGL doesn’t support rotating widgets, and the slider cannot display in 45-degree increments (only horizontally and vertically).
