Remove a grid's frame
Currently native_sim provided by the Zephyr project, later STM32H562.
v8
I’m nesting grids. There are two cells at the top level
 ______________
|  #1  |   #2  |
|______|_______|
and those cells are filled with another grid.
In #1 I display a bunch of images etc. and in #2 I display buttons to interact with #1.
The intended application has no touch screen, so I’m faking those physical button inputs by expanding the screen with virtual buttons.
My idea is to have a simple defien that allows me to switch between the virtual environment and the actual board.
grafik
Unfortunately, those grid add a gray frame.
How do I get rid of the gray frame?
What did I try so far?
lv_obj_t * container = lv_obj_create(lv_scr_act());
lv_obj_remove_style_all(container);
lv_obj_set_style_grid_column_dsc_array(container, col_dsc, 0);
lv_obj_set_style_grid_row_dsc_array(container, row_dsc, 0);
lv_obj_set_size(container, SCR_RES_X+BTN_RES_X, SCR_RES_Y);
lv_obj_align(container, LV_ALIGN_TOP_LEFT, 0, 0);
lv_obj_set_layout(container, LV_LAYOUT_GRID);
lv_obj_clear_flag(container, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_set_style_radius(container, 0, LV_PART_MAIN);
lv_obj_set_style_pad_all(container, 0, LV_PART_MAIN);
lv_obj_set_style_pad_column(container, 0, LV_PART_MAIN);
lv_obj_set_style_pad_row(container, 0, LV_PART_MAIN);
The nested grids are similar.
