and now we dir include
This version work for esp32 if you want!
* @file lv_fs_fatfs.c
* For ESP32
* INCLUDES
#include <lvgl.h>
#include "ff.h"
#include <SD.h>
* DEFINES
#define SD_CS 4 // you're CS pin for SPI slave
#define DRIVE_LETTER 'S'
* TYPEDEFS
/* Create a type to store the required data about your file.*/
typedef FIL file_t;
/*Similarly to `file_t` create a type for directory reading too */
typedef FF_DIR dir_t;
* STATIC PROTOTYPES
static void fs_init(void);
static lv_fs_res_t fs_open (lv_fs_drv_t * drv, void * file_p, const char * path, lv_fs_mode_t mode);
static lv_fs_res_t fs_close (lv_fs_drv_t * drv, void * file_p);
static lv_fs_res_t fs_read (lv_fs_drv_t * drv, void * file_p, void * buf, uint32_t btr, uint32_t * br);
static lv_fs_res_t fs_write(lv_fs_drv_t * drv, void * file_p, const void * buf, uint32_t btw, uint32_t * bw);
static lv_fs_res_t fs_seek (lv_fs_drv_t * drv, void * file_p, uint32_t pos);
static lv_fs_res_t fs_size (lv_fs_drv_t * drv, void * file_p, uint32_t * size_p);
static lv_fs_res_t fs_tell (lv_fs_drv_t * drv, void * file_p, uint32_t * pos_p);
static lv_fs_res_t fs_remove (lv_fs_drv_t * drv, const char *path);
static lv_fs_res_t fs_trunc (lv_fs_drv_t * drv, void * file_p);
static lv_fs_res_t fs_rename (lv_fs_drv_t * drv, const char * oldname, const char * newname);
static lv_fs_res_t fs_free (lv_fs_drv_t * drv, uint32_t * total_p, uint32_t * free_p);
static lv_fs_res_t fs_dir_open (lv_fs_drv_t * drv, void * dir_p, const char *path);
static lv_fs_res_t fs_dir_read (lv_fs_drv_t * drv, void * dir_p, char *fn);
static lv_fs_res_t fs_dir_close (lv_fs_drv_t * drv, void * dir_p);
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
void lv_fs_if_init(void)
* Initialize your storage device and File System
fs_init();
* Register the file system interface in LittlevGL
/* Add a simple drive to open images */
lv_fs_drv_t fs_drv; /*A driver descriptor*/
lv_fs_drv_init(&fs_drv);
/*Set up fields...*/
fs_drv.file_size = sizeof(file_t);
fs_drv.letter = DRIVE_LETTER;
fs_drv.open_cb = fs_open;
fs_drv.close_cb = fs_close;
fs_drv.read_cb = fs_read;
fs_drv.write_cb = fs_write;
fs_drv.seek_cb = fs_seek;
fs_drv.tell_cb = fs_tell;
fs_drv.free_space_cb = fs_free;
fs_drv.size_cb = fs_size;
fs_drv.remove_cb = fs_remove;
fs_drv.rename_cb = fs_rename;
fs_drv.trunc_cb = fs_trunc;
fs_drv.rddir_size = sizeof(dir_t);
fs_drv.dir_close_cb = fs_dir_close;
fs_drv.dir_open_cb = fs_dir_open;
fs_drv.dir_read_cb = fs_dir_read;
lv_fs_drv_register(&fs_drv);
* STATIC FUNCTIONS
/* Initialize your Storage device and File system. */
/* Initialisation de la carte SD */
Serial.print(F("Init SD card... "));
if (!SD.begin(SD_CS)) {
Serial.println(F("FAIL"));
for (;;); // appui sur bouton RESET
* Open a file
* @param drv pointer to a driver where this function belongs
* @param file_p pointer to a file_t variable
* @param path path to the file beginning with the driver letter (e.g. S:/folder/file.txt)
* @param mode read: FS_MODE_RD, write: FS_MODE_WR, both: FS_MODE_RD | FS_MODE_WR
* @return LV_FS_RES_OK or any error from lv_fs_res_t enum
uint8_t flags = 0;
if(mode == LV_FS_MODE_WR) flags = FA_WRITE | FA_OPEN_ALWAYS;
else if(mode == LV_FS_MODE_RD) flags = FA_READ;
else if(mode == (LV_FS_MODE_WR | LV_FS_MODE_RD)) flags = FA_READ | FA_WRITE | FA_OPEN_ALWAYS;
FRESULT res = f_open((file_t*) file_p, path, flags);
if(res == FR_OK) {
f_lseek((file_t*) file_p, 0);
return LV_FS_RES_OK;
} else {
return LV_FS_RES_UNKNOWN;
* Close an opened file
* @param file_p pointer to a file_t variable. (opened with lv_ufs_open)
* @return LV_FS_RES_OK: no error, the file is read
* any error from lv_fs_res_t enum
f_close((file_t*) file_p);
* Read data from an opened file
* @param buf pointer to a memory block where to store the read data
* @param btr number of Bytes To Read
* @param br the real number of read bytes (Byte Read)
FRESULT res = f_read((file_t*) file_p, buf, btr, (UINT*)br);
if(res == FR_OK) return LV_FS_RES_OK;
else return LV_FS_RES_UNKNOWN;
* Write into a file
* @param buf pointer to a buffer with the bytes to write
* @param btr Bytes To Write
* @param br the number of real written bytes (Bytes Written). NULL if unused.
FRESULT res = f_write((file_t*) file_p, buf, btw, (UINT*)bw);
* Set the read write pointer. Also expand the file size if necessary.
* @param file_p pointer to a file_t variable. (opened with lv_ufs_open )
* @param pos the new position of read write pointer
f_lseek((file_t*) file_p, pos);
* Give the size of a file bytes
* @param size pointer to a variable to store the size
(*size_p) = f_size(((file_t *)file_p));
* Give the position of the read write pointer
* @param pos_p pointer to to store the result
*pos_p = f_tell(((file_t *)file_p));
* Delete a file
* @param path path of the file to delete
lv_fs_res_t res = LV_FS_RES_NOT_IMP;
/* Add your code here*/
return res;
* Truncate the file size to the current position of the read write pointer
* @param file_p pointer to an 'ufs_file_t' variable. (opened with lv_fs_open )
f_sync((file_t*) file_p); /*If not syncronized fclose can write the truncated part*/
f_truncate((file_t*) file_p);
* Rename a file
* @param oldname path to the file
* @param newname path with the new name
* @return LV_FS_RES_OK or any error from 'fs_res_t'
FRESULT res = f_rename(oldname, newname);
* Get the free and total size of a driver in kB
* @param letter the driver letter
* @param total_p pointer to store the total size [kB]
* @param free_p pointer to store the free size [kB]
return res;
* Initialize a 'fs_read_dir_t' variable for directory reading
* @param dir_p pointer to a 'fs_read_dir_t' variable
* @param path path to a directory
FRESULT res = f_opendir((dir_t*)dir_p, path);
* Read the next filename form a directory.
* The name of the directories will begin with '/'
* @param dir_p pointer to an initialized 'fs_read_dir_t' variable
* @param fn pointer to a buffer to store the filename
FRESULT res;
FILINFO fno;
fn[0] = '\0';
do {
res = f_readdir((dir_t*)dir_p, &fno);
if(res != FR_OK) return LV_FS_RES_UNKNOWN;
if(fno.fattrib & AM_DIR) {
fn[0] = '/';
strcpy(&fn[1], fno.fname);
else strcpy(fn, fno.fname);
} while(strcmp(fn, "/.") == 0 || strcmp(fn, "/..") == 0);
* Close the directory reading
f_closedir((dir_t*)dir_p);
