In win_drv.h there’s a place where a variable might be used uninitialized, and cause errors.
PC simulator with codeblocks, lvgl version 7.0-dev
What do you experience?
I was sending a LV_EVENT_REFRESH to a screen, to refresh it. Then, the program aborted with 0 result. Debugging the process, I have seen that in win_drv.c a message with WM_QUIT was received. I have seen that the WM_QUIT is the same value as LV_EVENT_REFRESH (in the v7 version).
Inspecting the code, I have seen that if no message is received, the checking of the message is done, and that shouldn’t be correct.
/You code here/
This is the original code:
static void msg_handler(void *param)
(void)param;
MSG msg;
BOOL bRet;
if( (bRet = PeekMessage( &msg, NULL, 0, 0, TRUE )) != 0)
if (bRet == -1)
return;
TranslateMessage(&msg);
DispatchMessage(&msg);
if(msg.message == WM_QUIT)
lv_win_exit_flag = true;
In this code, if the PeekMessage function returns 0, the msg.message == WM_QUIT check is done, but the msg variable might be uninitialized (if the function has not changed it), which I suspect was happening to me.
I have put the checking inside the “if”, to avoid checking the msg variable if a message has not been received. It results like this
(void)param;
MSG msg;
BOOL bRet;
if (bRet == -1)
return;
Changing this, I don’t receive the exit message any more
Alex
