ttgo v1 2020 watch (esp32 with tft screen via spi)
What LVGL version are you using? 7.1.1. (since lilly go hasnt ported 8x)
What do you want to achieve? call a new screen from a call back function
What have you tried so far? reading documentation on 7.1.1
#define LILYGO_WATCH_2020_V1
#define LILYGO_WATCH_LVGL
#include <LilyGoWatch.h>
int myVar_width = 480;
int myVar_height = 270;
const int vib = 4;
bool button_status = false ;
int buttonstate = 0;
int button_press_current_status = 0;
int button_press_last_status = 0;
bool auto_del = true;
TTGOClass *ttgo;
static void go_to_sleep(lv_obj_t *screen_1, lv_event_t event){
esp_deep_sleep_start();}
static void load_page_2(lv_obj_t *screen_2, lv_event_t event){
lv_scr_load_anim(screen_2, LV_SCR_LOAD_ANIM_OVER_LEFT, 10, 10,auto_del);
lv_scr_load(screen_2);
static void load_page_1(lv_obj_t *screen_1, lv_event_t event){
lv_scr_load_anim(screen_1, LV_SCR_LOAD_ANIM_OVER_RIGHT, 10, 10,auto_del);
lv_scr_load(screen_1);
static void event_handler(lv_obj_t *obj, lv_event_t event)
if (event == LV_EVENT_CLICKED) {
Serial.printf("Clicked\n");
digitalWrite(vib,HIGH);
delay(250);
digitalWrite(vib,LOW);}
else if (event == LV_EVENT_VALUE_CHANGED) {
Serial.printf("Toggled\n");
delay(250);
void setup()
pinMode(vib,OUTPUT);
pinMode(36,INPUT);
Serial.begin(115200);
ttgo = TTGOClass::getWatch();
ttgo->begin();
ttgo->openBL();
ttgo->lvgl_begin();
ttgo->tft->init(TFT_BLACK);
ttgo->tft->setRotation(2);
esp_sleep_enable_ext0_wakeup(GPIO_NUM_36,true);
lv_obj_t * screen_2 = lv_obj_create(NULL, NULL);
LV_IMG_DECLARE(screen_1_background_image);
lv_obj_t * screen_1 = lv_obj_create(NULL, NULL);
lv_obj_t *label;
lv_obj_t *btn1 = lv_btn_create(screen_1, NULL); //create the object button and what screen
lv_obj_set_event_cb(btn1, event_handler); //assign it a function
lv_obj_align(btn1, NULL, LV_ALIGN_IN_TOP_LEFT,5,5); //X,Y coord placement
lv_obj_set_size(btn1,70,40); //button metrics
label = lv_label_create(btn1, NULL); //placing and defining
lv_label_set_text(label, "MENU"); //visual label
lv_obj_t *btn2 = lv_btn_create(screen_1, NULL);
lv_obj_set_event_cb(btn2, event_handler);
lv_obj_align(btn2, NULL, LV_ALIGN_IN_LEFT_MID, 5, 0);
lv_obj_set_size(btn2,90,50);
label = lv_label_create(btn2, NULL);
lv_label_set_text(label, "CONNECT");
lv_obj_t *btn3 = lv_btn_create(screen_1, NULL);
lv_obj_set_event_cb(btn3, event_handler);
lv_obj_align(btn3, NULL, LV_ALIGN_IN_BOTTOM_LEFT,5,-5);
lv_obj_set_size(btn3,80,40);
label = lv_label_create(btn3, NULL);
lv_label_set_text(label, "STATUS");
lv_obj_t *btn4 = lv_btn_create(screen_1, NULL);
lv_obj_set_event_cb(btn4,go_to_sleep);
lv_obj_align(btn4, NULL, LV_ALIGN_IN_TOP_RIGHT,45,5);
lv_obj_set_size(btn4,80,50);
label = lv_label_create(btn4, NULL);
lv_label_set_text(label, "SLEEP");
lv_obj_t *btn5 = lv_btn_create(screen_1, NULL);
lv_obj_set_event_cb(btn5, event_handler);
lv_obj_align(btn5, NULL, LV_ALIGN_IN_RIGHT_MID,15,0);
lv_obj_set_size(btn5,110,50);
label = lv_label_create(btn5, NULL);
lv_label_set_text(label, "DISCONNECT");
lv_obj_t *btn6 = lv_btn_create(screen_1, NULL);
lv_obj_set_event_cb(btn6, load_page_2);
lv_obj_align(btn6, NULL, LV_ALIGN_IN_BOTTOM_RIGHT,55,-5);
lv_obj_set_size(btn6,70,40);
label = lv_label_create(btn6, NULL);
lv_label_set_text(label, "EXIT");
lv_obj_t *btn7 = lv_btn_create(screen_2, NULL);
lv_obj_set_event_cb(btn7, load_page_1);
lv_obj_align(btn7, NULL, LV_ALIGN_CENTER,0,0);
lv_obj_set_size(btn7,0,0);
label = lv_label_create(btn7, NULL);
lv_label_set_text(label, "BACK");
void loop(){
lv_task_handler();
delay(5);}
when i try to call screen 2 it crashes and turns the screen black then goes back to screen 1 could anyone tell me what i did wrong here? thank you in advance
