online font create not work
I use qt create
lvgl version: V9.0
change item for font create, but no use,sth was error.
I use qt create
lvgl version: V9.0
You must enter something in the “range” or “symbols” field. This tells the converter which characters to convert.
very thanks,but some font no symbols.selected item display a rect. ![]()
If the font does not have those symbols it cannot display them, they will just be replaced by an empty rectangle. If you use a font that supports those letters you can just enter them in “symbols” or if they are special characters, put the UTF-8 hex in range field.
this symbols
Hello, please try this:
in the “range” field, type only 0xF000. Leave “Symbols” field empty. See if that symbol at least works, then try adding the whole range in “range” field and still leave symbols empty.
Very strange… can you send me the .ttf file?
ok,what’s your email. ![]()
Check your private messages.
