Hey Guys,
i have running a 320x240px display on the esp32 with the lvgl v7.0 and i use this code to set it and the loop up in my code. now i wanna change to v8.0 but i dont find an example thet get me the information how the syntax was changing here. I hope anyone can help me there.
static void loop1code(void *pvParameters) {
//tft_start();
//startup_jpeg();
xGuiSemaphore = xSemaphoreCreateMutex();
lvgl_driver_init();
lv_color_t* buf1 = (lv_color_t*)heap_caps_malloc(DISP_BUF_SIZE * sizeof(lv_color_t), MALLOC_CAP_DMA);
assert(buf1 != NULL);
static lv_color_t *buf2 = NULL;
uint32_t size_in_px = DISP_BUF_SIZE;
lv_disp_buf_init(&disp_buf, buf1, buf2, size_in_px);
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = disp_driver_flush;
disp_drv.buffer = &disp_buf;
/* Register Input #Touch */
#if CONFIG_LV_TOUCH_CONTROLLER != TOUCH_CONTROLLER_NONE
lv_indev_drv_t indev_drv;
indev_drv.read_cb = touch_driver_read;
/* Create and start a periodic timer interrupt to call lv_tick_inc */
const esp_timer_create_args_t periodic_timer_args = {
.callback = &lv_tick_task,
.name = "periodic_gui"
esp_timer_handle_t periodic_timer;
ESP_ERROR_CHECK(esp_timer_create(&periodic_timer_args, &periodic_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer, LV_TICK_PERIOD_MS * 1000));
dp_views();
while (1) {
/* Delay 1 tick (assumes FreeRTOS tick is 10ms */
/* Try to take the semaphore, call lvgl related function on success */
if (pdTRUE == xSemaphoreTake(xGuiSemaphore, portMAX_DELAY)) {
lv_task_handler();
xSemaphoreGive(xGuiSemaphore);
/* A task should NEVER return */
free(buf1);
vTaskDelete(NULL);
And how i can understand this?:
/* Since LVGL v8 LV_HOR_RES_MAX and LV_VER_RES_MAX are not defined, so
* print it only if they are defined. */
Best regards MN(Trackhe)
