STM32F7
9.2
Hi all, I’m new to LVGL and I’m building an acceleration/ G-Force gauge. I want to be able to move the red dot on the display (as below) based on the acceleration measured.
I have tried just a simple test where I move the dot back and forth using lv_obj_set_pos() function but for some reason the dot only remains in one place and does not switch between the two.
lv_tick_set_cb(HAL_GetTick);
lv_display_t* display = lv_display_create(480, 480);
lv_display_set_buffers(display, (void*) 0xC007A120, NULL, 480*480*2, LV_DISP_RENDER_MODE_DIRECT);
lv_display_set_flush_cb(display, my_flush_cb);
ui_init();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
lv_timer_handler_run_in_period(5);
lv_obj_set_pos(objects.obj8, 100, 100);
lv_obj_set_pos(objects.obj8, 300, 300);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
This is just a snippet from the main function. I have verified that the flushing all works correctly but for some reason the dot just moves to (300,300) and stays there.
This is what the UI looks like.
Thanks in advance!
