Makerfabs Matouch 7 touch not working
Hi, after several trials I was able to appear an Hello World on my Makerfabs Matouch 7 inc display using LovyanGFX and LVGL 9.1
The issues I can’t solve is the touchscreen: the touch is working fine and i can read the coordinate of each touch but LVGL is not able to handle it.
I implemented the function:
void touchscreen_read(lv_indev_t * indev, lv_indev_data_t*data)
  if(lcd.getTouch(&x, &y)) {
    data->point.x = x;
    data->point.y = y;
  } else {
  Serial.println(data->point.x);
But it doesn’t read the touch. With the same code in the loop section I can print the touch coordinates on serial. IT seems like this function doesn’t run. I used this code to implement the touch in LVGL:
// Start LVGL
  // Initialize an LVGL input device object (Touchscreen)
  lv_indev_t* indev = lv_indev_create();
  // Set the callback function to read Touchscreen input
  lv_indev_set_read_cb(indev, touchscreen_read);
Can anybody help me?
The board i use has the following specs:
  • Controller: ESP32-S3-WROOM-1, PCB Antenna, 16MB Flash, 8MB PSRAM, ESP32-S3-WROOM-1-N16R8
  • Wireless: Wifi& Bluetooth 5.0
  • LCD: 7 inch High Lightness IPS
  • FPS: >30
  • Resolution: 800480/1024600
  • LCD interface: RGB 565
  • Touch Panel: 5 Points Touch, Capacitive
  • Touch Panel Driver: GT911
  • USB: Dual USB Type-C(one for USB-to-UART and one for native USB)
  • UART to UART Chip: CP2104
  • Power Supply: USB Type-C 5.0V(4.0V~5.25V)
  • Button: Flash button and reset button
  • Mabee interface: 1I2C;1GPIO
  • MicroSD: Yes
  • Arduino support: Yes
  • Type-C Power Delivery: Not Supported
  • Operation temperature: -40℃ to +85℃
    Thanks
