I have some long running circular horizontal scrolling animations going on, and I can clearly see that the animation is jittery.
I have narrowed down the problem to LVGL skipping frames. Before I move forward to try to debug this problem, I want to check whether this is even a bug or if it’s expected behavior.
I have LV_DISP_DEF_REFR_PERIOD
set to 30. The animation speed is set to 33 pixels/s as follows:
lv_style_set_anim_speed(&label_style, 33);
These are logs explaining the issue:
// The display is refreshed with this call to the timer handler
[Info] (18.857, +0) lv_timer_handler: begin (in lv_timer.c line #70)
[Info] (18.857, +0) lv_timer_exec: calling timer callback: 0x6001ff41 (in lv_timer.c line #319)
[Info] (18.857, +0) _lv_disp_refr_timer: begin (in lv_refr.c line #293)
[Info] (18.871, +14) call_flush_cb: Calling flush_cb on (0;0)(255;63) area with 0x20008760 image pointer (in lv_refr.c line #1044)
[Info] (18.871, +0) _lv_disp_refr_timer: finished (in lv_refr.c line #445)
[Info] (18.871, +0) lv_timer_exec: timer callback 0x6001ff41 finished (in lv_timer.c line #321)
[Info] (18.872, +1) lv_timer_handler: finished (15 ms until the next timer call) (in lv_timer.c line #145)
// Called the timer handler 15 ms later, as requested by LVGL, but nothing was rendered
// This should have refreshed the display in order to keep the FPS close to 30 fps
[Info] (18.887, +15) lv_timer_handler: begin (in lv_timer.c line #70)
[Info] (18.887, +0) lv_timer_exec: calling timer callback: 0x60038e79 (in lv_timer.c line #319)
[Info] (18.887, +0) lv_timer_exec: timer callback 0x60038e79 finished (in lv_timer.c line #321)
[Info] (18.887, +0) lv_timer_handler: finished (30 ms until the next timer call) (in lv_timer.c line #145)
// Called the timer handler 30 ms later, as requested by LVGL, but nothing was rendered either
[Info] (18.917, +30) lv_timer_handler: begin (in lv_timer.c line #70)
[Info] (18.917, +0) lv_timer_exec: calling timer callback: 0x60038e79 (in lv_timer.c line #319)
[Info] (18.917, +0) lv_timer_exec: timer callback 0x60038e79 finished (in lv_timer.c line #321)
[Info] (18.917, +0) lv_timer_handler: finished (0 ms until the next timer call) (in lv_timer.c line #145)
// Because the timer handler returned 0 to next call, it gets called immediately
// This call finally refreshes the display, 60 ms after the last refresh
[Info] (18.917, +0) lv_timer_handler: begin (in lv_timer.c line #70)
[Info] (18.917, +0) lv_timer_exec: calling timer callback: 0x6001ff41 (in lv_timer.c line #319)
[Info] (18.917, +0) _lv_disp_refr_timer: begin (in lv_refr.c line #293)
[Info] (18.930, +13) call_flush_cb: Calling flush_cb on (0;0)(255;63) area with 0x20006760 image pointer (in lv_refr.c line #1044)
[Info] (18.931, +1) _lv_disp_refr_timer: finished (in lv_refr.c line #445)
[Info] (18.931, +0) lv_timer_exec: timer callback 0x6001ff41 finished (in lv_timer.c line #321)
[Info] (18.931, +0) lv_timer_handler: finished (16 ms until the next timer call) (in lv_timer.c line #145)
I did go through the changelog to see if there was a fix in a newer version related to this but I didn’t find one.
NXP MIMXRT1010, arm gcc 10.3
Some commit after 8.2.0:
340d45cfa91b7108d43af906fc51b1c431877827
Stable frame rate, get rid of jittery animations/scrolling
Call lv_timer_handler()
more often.
I’d post the animation but the jitter is not really visible in video.
