Hello everyone i have some compilation warnings in lvgl 8.0.0 version
here is part of compilation log where warnings occured
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
compiling lv_theme_default.c...
..\LVGL\src\extra\themes\default\lv_theme_default.c(207): warning: #188-D: enumerated type mixed with another type
..\LVGL\src\extra\themes\default\lv_theme_default.c: 1 warning, 0 errors
compiling lv_flex.c...
..\LVGL\src\extra\layouts\flex\lv_flex.c(94): warning: #188-D: enumerated type mixed with another type
LV_STYLE_FLEX_MAIN_PLACE = lv_style_register_prop() |
V_STYLE_PROP_LAYOUT_REFR;
..\LVGL\src\extra\layouts\flex\lv_flex.c(95): warning: #188-D: enumerated type mixed with another type
LV_STYLE_FLEX_CROSS_PLACE = lv_style_register_prop() |
..\LVGL\src\extra\layouts\flex\lv_flex.c(96): warning: #188-D: enumerated type mixed with another type
LV_STYLE_FLEX_TRACK_PLACE = lv_style_register_prop() |
..\LVGL\src\extra\layouts\flex\lv_flex.c: 3 warnings, 0 errors
compiling lv_grid.c...
..\LVGL\src\extra\layouts\grid\lv_grid.c(103): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_COLUMN_DSC_ARRAY = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(104): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_ROW_DSC_ARRAY = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(105): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_COLUMN_ALIGN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(106): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_ROW_ALIGN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(108): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_ROW_SPAN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(109): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_ROW_POS = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(110): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_COLUMN_SPAN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(111): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_COLUMN_POS = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(112): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_X_ALIGN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(113): warning: #188-D: enumerated type mixed with another type
LV_STYLE_GRID_CELL_Y_ALIGN = lv_style_register_prop() |
..\LVGL\src\extra\layouts\grid\lv_grid.c(554): warning: #188-D: enumerated type mixed with another type
lv_grid_align_t col_align = get_cell_col_align(item);
..\LVGL\src\extra\layouts\grid\lv_grid.c(555): warning: #188-D: enumerated type mixed with another type
lv_grid_align_t row_align = get_cell_row_align(item);
..\LVGL\src\extra\layouts\grid\lv_grid.c: 12 warnings, 0 errors
compiling lv_font_fmt_txt.c...
..\LVGL\src\font\lv_font_fmt_txt.c(137): warning: #111-D: statement is unreachable
return NULL;
..\LVGL\src\font\lv_font_fmt_txt.c: 1 warning, 0 errors
..\LVGL\src\extra\widgets\span\lv_span.c(61): warning: #1295-D: Deprecated declaration lv_get_snippet_cnt - give arg types
static uint16_t lv_get_snippet_cnt();
..\LVGL\src\extra\widgets\span\lv_span.c(821): warning: #546-D: transfer of control bypasses initialization of:
variable "ellipsis_valid" (declared at line 825)
goto Next_line_init;
..\LVGL\src\extra\widgets\span\lv_span.c: 2 warnings, 0 errors
compiling lv_bar.c...
..\LVGL\src\widgets\lv_bar.c(133): warning: #188-D: enumerated type mixed with another type
lv_bar_set_value(obj, bar->cur_value,
alse);
..\LVGL\src\widgets\lv_bar.c(137): warning: #188-D: enumerated type mixed with another type
alse);
..\LVGL\src\widgets\lv_bar.c: 2 warnings, 0 errors
compiling lv_roller.c...
..\LVGL\src\widgets\lv_roller.c(334): warning: #188-D: enumerated type mixed with another type
refr_position(obj,
alse);
..\LVGL\src\widgets\lv_roller.c(337): warning: #188-D: enumerated type mixed with another type
refr_position(obj,
alse);
..\LVGL\src\widgets\lv_roller.c(367): warning: #188-D: enumerated type mixed with another type
refr_position(obj,
rue);
..\LVGL\src\widgets\lv_roller.c(384): warning: #188-D: enumerated type mixed with another type
refr_position(obj,
rue);
..\LVGL\src\widgets\lv_roller.c(392): warning: #188-D: enumerated type mixed with another type
lv_roller_set_selected(obj, roller->sel_opt_id + 1,
rue);
..\LVGL\src\widgets\lv_roller.c(400): warning: #188-D: enumerated type mixed with another type
lv_roller_set_selected(obj, roller->sel_opt_id - 1,
rue);
..\LVGL\src\widgets\lv_roller.c: 6 warnings, 0 errors
compiling lv_style.c...
..\LVGL\src\misc\lv_style.c(75): warning: #188-D: enumerated type mixed with another type
return act_id;
..\LVGL\src\misc\lv_style.c: 1 warning, 0 errors
compiling lv_mem.c...
..\LVGL\src\misc\lv_mem.c(302): warning: #111-D: statement is unreachable
return NULL;
..\LVGL\src\misc\lv_mem.c: 1 warning, 0 errors
compiling lv_tlsf.c...
..\LVGL\src\misc\lv_tlsf.c(928): warning: #68-D: integer conversion resulted in a change of sign
offset_to_block(pool, -(int)block_header_overhead);
..\LVGL\src\misc\lv_tlsf.c(1034): warning: #68-D: integer conversion resulted in a change of sign
block = offset_to_block(mem, -(tlsfptr_t)block_header_overhead);
..\LVGL\src\misc\lv_tlsf.c(1052): warning: #68-D: integer conversion resulted in a change of sign
block_header_t* block = offset_to_block(pool, -(int)block_header_overhead);
..\LVGL\src\misc\lv_tlsf.c: 3 warnings, 0 errors
compiling lv_hal_disp.c...
..\LVGL\src\hal\lv_hal_disp.c(389): warning: #188-D: enumerated type mixed with another type
return disp->driver->rotated;
..\LVGL\src\hal\lv_hal_disp.c: 1 warning, 0 errors
ive downloaded this version from github today.
