Lv_scr_load_anim does not work properly in LVGL 7.81 and 7.9, But it works fine on LVGL7.8.0
VS2019
V7.8.1 or V7.9.0
void test_screen_1(void)
lv_obj_t* one = lv_obj_create(NULL, NULL);
lv_obj_t* label = lv_label_create(one, NULL);
lv_obj_set_size(one, LV_HOR_RES, LV_VER_RES);
lv_obj_align(label, one, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_style_local_bg_color(one, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT,
LV_COLOR_YELLOW);
lv_label_set_text(label, "ONE");
lv_scr_load_anim(one, LV_SCR_LOAD_ANIM_FADE_ON, 100, 0, true);
void test_screen_2(void)
lv_obj_t* two = lv_obj_create(NULL, NULL);
lv_obj_t* label = lv_label_create(two, NULL);
lv_obj_set_size(two, LV_HOR_RES, LV_VER_RES);
lv_obj_align(label, two, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_style_local_bg_color(two, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT,
LV_COLOR_BLUE);
lv_label_set_text(label, "TWO");
lv_scr_load_anim(two, LV_SCR_LOAD_ANIM_FADE_ON, 100, 0, true);
static void test_screen_task(struct _lv_task_t* task)
static bool toggle_flag;
if (toggle_flag)
test_screen_2();
test_screen_1();
toggle_flag = !toggle_flag;
int main(int argc, char** argv)
/*Initialize LittlevGL*/
/*Initialize the HAL for LittlevGL*/
hal_init();
lv_obj_t * scr = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(scr, LV_HOR_RES, LV_VER_RES);
lv_task_create(test_screen_task, 1000, LV_TASK_PRIO_LOW, NULL);
while (1) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_task_handler();
Sleep(10); /*Just to let the system breathe */
return 0;
The following is the error log information
Error: lv_obj_get_disp (lv_obj.c #2126 lv_obj_get_disp())
Error: NULL pointer (0x00000000) (lv_debug.c #127 lv_debug_log_error())
