I am using a esp32 board with ssd1306 128x64 oled display. I am trying to render a qr code using lv_qr_code library, the lv_qrcode_create()
function works fine. But on calling lv_qrcode_update();
, there’s a stack overflow and board crashes
ESP32
7.0
render qr code on the ssd1306 oled
This is the logs I got
I (1054) lvgl_helpers: Initializing I2C master for display
I (1064) lvgl_helpers: Initializing I2C master port 0...
I (1064) lvgl_helpers: SDA pin: 21, SCL pin: 22, Speed: 400000 (Hz)
I (1074) lvgl_helpers: Setting I2C master configuration...
I (1084) lvgl_helpers: Installing I2C master driver...
I (1104) bdg: init
***ERROR*** A stack overflow in task gui has been detected.
Backtrace:0x4008851f:0x3ffc98a0 0x40088bbd:0x3ffc98c0 0x40088e65:0x3ffc98e0 0x40089ad2:0x3ffc9960 0x40088f58:0x3ffc9980 0x40088f0e:0x00000000 |<-CORRUPTED
0x4008851f: panic_abort at /home/vedant/esp/esp-idf/components/esp_system/panic.c:330
0x40088bbd: esp_system_abort at /home/vedant/esp/esp-idf/components/esp_system/system_api.c:106
0x40088e65: vApplicationStackOverflowHook at /home/vedant/esp/esp-idf/components/freertos/xtensa/port.c:436
0x40089ad2: vTaskSwitchContext at /home/vedant/esp/esp-idf/components/freertos/tasks.c:2770
0x40088f58: _frxt_dispatch at /home/vedant/esp/esp-idf/components/freertos/xtensa/portasm.S:431
0x40088f0e: _frxt_int_exit at /home/vedant/esp/esp-idf/components/freertos/xtensa/portasm.S:231
image_qr_code_group_4_2 = lv_qrcode_create(scr4[2], 50, lv_color_hex3(0x000), lv_color_hex3(0xfff));
const char *data = "hello-world";
lv_qrcode_update(image_qr_code_group_4_2, data, strlen(data));
