I just updated a project from LVGL 7.10.1 to latest release, 8.0.2.
Everything is fine except that the lv_obj_set_auto_realign function doesn’t exist anymore.
Is there a new function to achieve the same behavior or the new layout system is not compatible ?
For layout, I only changed the old lv_obj_align to its new counterpart and lv_obj_align_to when relevant.
hello Patrick, I have the same problem. I searched in the LVGL documents and found nothing.
if you find how to solve this problem, please share your answer
I don’t have any solution.
I am now using the grid layout and I don’t need lv_obj_align_to anymore.
I achieve alignment with cells.
Thanks for your help.
In v8, all alignments are saved and reapplied automatically if needed. So auto_realign = true is the default.
However, it’s no the case with lv_obj_align_to()
. Here you need to apply the alignment again manually if required.
It’s just a personal experience, but basically I never use lv_obj_align_to
. If an object needs to be aligned to a sibling or more or less unrelated object, probably a layout (flex or grid) is a better option.
Have to chime in, but I personally feel that layouts are overkill in cases where you just want, say, two labels to align next to each other, and the content of one label changes. I do miss this from v7; obviously, this is solved by having the align code follow any code to set the labels text, but I preferred the method in v7.
To bring lv_obj_align_to(obj, base, ...)
to a next level we need to store all obj - base
connections so that either obj
or base
changes we can reapply the align.
Note that in v7, only base
were stored in obj
. Therefore if base
changed obj
wasn’t updated.
I have an idea how to handle this events and event user data. This way it can be an option module that can be enabled in lv_conf.h
. If it were add we should deprecate the lv_obj_align_to()
function.
