Lv_obj_del(...) and signal LV_SIGNAL_CLEANUP and free allocated variable
I create a object with allocated variable in a obj’s ext_attr.
When the obj is deleted by lv_obj_del(...),
if I want to free this allocated variable automatically
I place free(...) api in LV_SIGNAL_CLEANUP signal .
Is this correct ?
Or is there better method for cleaning up the allocated-variable
when the object is deleted?
Thank you.
typedef struct {
  uint8_t* buf;   //  for allocated variable
} lv_mywidget_ext_t;
lv_obj_t* lv_mywidget_create(lv_obj_t* par, lv_obj_t* copy)
     ext->buf = (uint8_t*) lv_mem_alloc( 1024);  //  allocated var.
static lv_res_t lv_mywidget_signal(lv_obj_t * label_grad, lv_signal_t sign, void * param)
  if (sign == LV_SIGNAL_CLEANUP) {
    free(ext->buf); ext->buf = NULL;   //  For automatically free, I place this code is right ?
  return res;
You can use LV_EVENT_DELETE which is more user-friendly.
Thank you a lot. :slight_smile:
You’re welcome! :slight_smile:
