LV_LABEL_LONG_TXT_HINT doesn't seem to have an impact on textarea rendering speeds
NXP 1064 RT EVK
7.0
Display a ~30kb text file in a text area.
Setting LV_LABEL_LONG_TXT_HINT to 1.
Result
There is no change in rendering speed, even when attempting to render just 5kb of the file, it is still as laggy during scrolling with/without the define set.
If you are really using 7.0 I would suggest updating to 7.9.1. There shouldn’t be any incompatibilities, and there are a lot of bugfixes. :wink:
@kisvegabor
I’ve tested it with 10k text on PC and I do see a big difference. See:
https://drive.google.com/drive/folders/1JC_vCTtwvZLeOLEEY_NLFaaeZRsj-nZW?usp=sharing
Try LV_USE_BIDI 0 because it also slows down scrollig.
If you don’t need to edit the text I suggest using an lv_label on lv_page because it has a much lower owerhead.
