lv_example_img_3 display error
if remove the statement lv_anim_set_playback_time(&a, 3000);
When the image show from zoom value 256 to 128, the image that has zoom value 256 still on the screen, not be cleared.
Visual Studio 2019 simulator
LVGL V8.3
Clear the previous image shown from the screen
#include "../../lv_examples.h"
#if LV_USE_IMG && LV_BUILD_EXAMPLES
static void set_angle(void* img, int32_t v)
lv_img_set_angle(img, v);
static void set_zoom(void* img, int32_t v)
lv_img_set_zoom(img, v);
* Show transformations (zoom and rotation) using a pivot point.
void lv_example_img_3(void)
LV_IMG_DECLARE(img_cogwheel_argb);
/*Now create the actual image*/
lv_obj_t* img = lv_img_create(lv_scr_act());
lv_img_set_src(img, &img_cogwheel_argb);
lv_obj_align(img, LV_ALIGN_CENTER, 50, 50);
lv_img_set_pivot(img, 0, 0); /*Rotate around the top left corner*/
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_var(&a, img);
lv_anim_set_exec_cb(&a, set_angle);
lv_anim_set_values(&a, 0, 3600);
lv_anim_set_time(&a, 5000);
lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
lv_anim_start(&a);
lv_anim_set_exec_cb(&a, set_zoom);
lv_anim_set_values(&a, 128, 256);
//lv_anim_set_playback_time(&a, 3000);
lv_anim_start(&a);
