<littlevGL 6.1>
In bool lv_disp_is_true_double_buf(lv_disp_t * disp), scr_size = disp->driver.hor_res * disp->driver.ver_res; Does it need to multiply bytes per pixel?
As when initialize frame buffer, the driver.buffer->size is widthhightbytes per pixel, lv_disp_is_true_double_buf() will be always return false even set double buffer.
Use the ```c
and ```
tags to format your code:
* Check the driver configuration if it's TRUE double buffered (both `buf1` and `buf2` are set and
* `size` is screen sized)
* @param disp pointer to to display to check
* @return true: double buffered; false: not double buffered
uint32_t scr_size = disp->driver.hor_res * disp->driver.ver_res;
if(lv_disp_is_double_buf(disp) && disp->driver.buffer->size == scr_size) {
return true;
} else {
return false;
If possible, add screenshots and/or videos about the current issue.
