Hello everyone,
Currently, I am working on using LittlevGL via MicroPython on a microcontroller. The display module I am using is a customized module. I wrote the display driver for this module both in C and transferring it to MicroPython module.
The board I am using is STM32L4R9I Discovery.
What do you experience?
Give a detailed description. “It doesn’t work” is not enough information for us to diagnose the issue.
When I copy example code of Loader or Auto-fit Container (moving objects in general). When using STM32CubeIDE to compile the code and load it into the board. Loader is extremely lagging. Also, the auto fit container did not change in size. When running in Ubuntu (MicroPython), those object did not show any sign of changing. Other static object such as buttons work okay.
What do you expect?
I expect have a loader like this:
https://docs.littlevgl.com/en/html/object-types/preload.html
Use the ```c
and ```
tags to format your code:
#include "lv_conf.h"
#include "display.h"
#include "lvgl/src/lv_hal/lv_hal.h"
#include "lvgl/lvgl.h"
#include "stm32l4xx_hal.h"
#include "stm32l4xx_hal_ltdc.h"
#include "stm32l4xx_hal_dma2d.h"
#include "stm32l4xx_hal_dsi.h"
#include "stm32l4xx_hal_rcc.h"
#include "stm32l4xx_hal_gfxmmu.h"
#include "stm32l4r9i_discovery.h"
#include "stm32l4r9i_discovery_lcd.h"
#include "stm32l4r9i_discovery_psram.h"
#include "log.h"
#define LAYER0_ADDRESS GFXMMU_VIRTUAL_BUFFER0_BASE
#define ActiveLayer LTDC_ACTIVE_LAYER_BACKGROUND
//**************STATIC PROTOTYPES**************
/* For LittlevGL */
static void my_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area,
lv_color_t *color_p);
/* LCD */
/* RAM */
static void CopyBuffer(uint32_t *pSrc, uint32_t *pDst, uint16_t x, uint16_t y, uint16_t xsize, uint16_t ysize);
// ************STATIC VARIABLES***************
extern LTDC_HandleTypeDef hltdc_discovery;
extern DSI_HandleTypeDef hdsi_discovery;
DSI_VidCfgTypeDef hdsivideo_handle;
DSI_PLLInitTypeDef dsiPllInit;
static uint32_t *my_fb = (uint32_t*)LAYER0_ADDRESS;
static DMA2D_HandleTypeDef hdma2d_discovery;
// ************ GLOBAL FUNCTION *************
// ********* initialize the display ***********
void tft_init(void) {
log_debug("enter tft\r\n");
/* Deactivate speculative/cache access to first FMC Bank to save FMC bandwidth */
FMC_Bank1_R->BTCR[0] = 0x000030D2;
BSP_PSRAM_Init();
BSP_LCD_Init();
BSP_LCD_SelectLayer(0);
BSP_LCD_Refresh();
static lv_color_t buf1[390 * 10];
// static lv_color_t buf2[390 * 10];
lv_disp_buf_init(&disp_buf, buf1, NULL, 390 * 10);
lv_disp_drv_t disp_drv; /*A variable to hold the drivers. Can be local variable*/
disp_drv.buffer = &disp_buf; /*Set an initialized buffer*/
log_debug("enter flush \r\n");
disp_drv.flush_cb = my_flush_cb;
log_debug("finish flush \r\n");
//lv_disp_t * disp;/*Set a flush callback to draw to the display*/
lv_disp_drv_register(&disp_drv); /*Regis ter the driver and save the created display objects*/
log_debug("exit\r\n");
static void my_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_p) {
log_debug("in my_flush,enter CopyBuffer\r\n");
CopyBuffer((uint32_t*)color_p, my_fb, area->x1, area->y1, lv_area_get_width(area), lv_area_get_height(area));
log_debug("in my_flush,exit CopyBuffer\r\n");
BSP_LCD_Refresh();
log_debug("in my_flush,enter FlushReady\r\n");
lv_disp_flush_ready(drv);
log_debug("in my_flush,exit FlushReady\r\n");
* @brief Copy an input RGB888 buffer to output RGB888 with output offset
* @param pSrc: Pointer to source buffer
* @param pDst: Output color
* @param x: Start x position
* @param y: Start y position
* @param xsize: width
* @param ysize: height
* @param ColorMode: Input color mode
* @retval None
uint32_t destination = (uint32_t)pDst + (y * 768 + x) * 4;
uint32_t source = (uint32_t)pSrc;
hdma2d_discovery.Instance = DMA2D;
/*##-1- Configure the DMA2D Mode, Color Mode and output offset #############*/
hdma2d_discovery.Init.Mode = DMA2D_M2M;
hdma2d_discovery.Init.ColorMode = DMA2D_OUTPUT_ARGB8888;
hdma2d_discovery.Init.OutputOffset = 768 - xsize; //// CHANGE FROM 1024 TO 768 TO FIX THE HORIZONTAL STRIBE
hdma2d_discovery.Init.AlphaInverted = DMA2D_REGULAR_ALPHA; /* No Output Alpha Inversion */
hdma2d_discovery.Init.RedBlueSwap = DMA2D_RB_REGULAR; /* No Output Red & Blue swap */
hdma2d_discovery.Init.BytesSwap = DMA2D_BYTES_REGULAR; /* Regular output byte order */
hdma2d_discovery.Init.LineOffsetMode = DMA2D_LOM_PIXELS; /* Pixel mode */
/*##-2- Foreground Configuration ###########################################*/
hdma2d_discovery.LayerCfg[1].InputColorMode = DMA2D_INPUT_ARGB8888;
hdma2d_discovery.LayerCfg[1].InputOffset = 0;
hdma2d_discovery.LayerCfg[1].AlphaMode = DMA2D_NO_MODIF_ALPHA;
hdma2d_discovery.LayerCfg[1].InputAlpha = 0xFF; /* Not used */
hdma2d_discovery.LayerCfg[1].RedBlueSwap = DMA2D_RB_SWAP; //DMA2D_RB_REGULAR; /* No ForeGround Red/Blue swap */
hdma2d_discovery.LayerCfg[1].AlphaInverted = DMA2D_REGULAR_ALPHA; /* No ForeGround Alpha inversion */
/* DMA2D Initialization */
if(HAL_DMA2D_Init(&hdma2d_discovery) == HAL_OK)
if(HAL_DMA2D_ConfigLayer(&hdma2d_discovery, 1) == HAL_OK)
if (HAL_DMA2D_Start(&hdma2d_discovery, source, destination, xsize, ysize) == HAL_OK)
/* Polling For DMA transfer */
HAL_DMA2D_PollForTransfer(&hdma2d_discovery, 10);
If possible, add screenshots and/or videos about the current issue.
What might be the cause of this problem? I read some similar issues as mine and their solution are enable LV_USE_ANIMATION ( set to 1 already) or reviewing flushing functions (I dont know what to fix).
