Load chart from SD-CARD
I want to load chart from SD-Card.
ESP32 WROVER
SD-Card
v7.5.4
ESP IDF v5
I use list_add_btn for file selecting, and when i scroll down and pick the bottom of the list I got this error. This file has 29 lines. But when i pick the top and select larger file it works greate.
I (19254) sdcard_history: 29
I (19298) MEM: Memory: all 115668 byte, free 114408 byte
Warn: Couldn't allocate memory. Size: 800       (lv_mem.c #208 lv_mem_alloc())
Warn: Couldn't allocate memory  (lv_mem.c #323 lv_mem_realloc())
Error: _lv_mem_buf_get  (lv_mem.c #533 _lv_mem_buf_get())
Error: Out of memory, can't allocate a new  buffer (increase your LV_MEM_SIZE/heap size (0x00000000)         (lv_debug.c #127 lv_debug_log_error())
SD-Card load:
void readFile(char * name){
	sprintf(path, "/S/%s", name);
    FILE *r_file = fopen(path, "r");
    if (r_file == NULL) {
    	ESP_LOGE("File read"," %s %d", path, strlen(path));
    	errorWin(TAGGG, "Failed to open file for reading");
        ESP_LOGE(TAGGG, "Failed to open file for reading");
        return;
    char buf[100];
    char buf_szam;
    int time = 0;
    float chart_value;
    while (fgets(buf, sizeof(buf), r_file)) {
        sscanf(buf, "%d s: %f", &time, &chart_value);
    ESP_LOGI("read", "%d sor van.", time);
    lv_obj_clean(scrChart);
    createscrHistoryChart(name,time);
    ESP_LOGI("sdcard_history", "%d", time);
    rewind(r_file);
        historydrawChart(chart_value, time);
        lv_task_handler();
    lv_scr_load(scrChart);
    fclose(r_file);
    size_t total_heap = esp_get_free_heap_size();
    size_t free_heap = esp_get_minimum_free_heap_size();
    ESP_LOGI("MEM", "Memory: all %d byte, free %d byte", total_heap, free_heap);
File choiser:
void createscrHistory(){
	DIR* dir = opendir("/S/");
	if (dir == NULL) {
	    return;
    lv_obj_t *file_list = lv_list_create(scrHistory, NULL);
    lv_obj_set_size(file_list, DISP_RES_X, DISP_RES_Y/1.3);
    lv_obj_set_pos(file_list, 0, 0);
	while (true) {
	    struct dirent* de = readdir(dir);
	    if (!de) {
	        break;
	    if(strstr(de->d_name, "_meres.txt")){
	    	//printf("Found file: %s\n", de->d_name);
            lv_obj_t *btn = lv_list_add_btn(file_list, LV_SYMBOL_FILE, de->d_name);
            lv_obj_set_event_cb(btn, event_handler_list);
	closedir(dir);
    lv_obj_t * labelbtn;
    exitBtn = lv_btn_create(scrHistory, NULL);
    lv_obj_align(exitBtn, NULL, LV_ALIGN_CENTER, +DISP_RES_X/3, +DISP_RES_Y/3);
    lv_obj_set_size(exitBtn, DISP_RES_X/4.3, DISP_RES_Y/7);
    labelbtn = lv_label_create(exitBtn, NULL);
    lv_label_set_text(labelbtn, "Exit");
    lv_obj_set_event_cb( exitBtn , event_handler_exit);
    lv_scr_load(scrHistory);
Hi @martin023 ,
In your code you are checking the ESP memory (Please note I am not familiar with the processor or toolset) I would suggest checking the LVGL memory instead as it may need to be increased slightly. The LVGL memory size is normally changed in the lv_conf.h file:
/* Size of the memory used by `lv_mem_alloc` in bytes (>= 2kB)*/
#  define LV_MEM_SIZE    (64U * 1024U)
To check the LVGL memory during run time you should be able to use this code:
  lv_mem_monitor_t mon;
  lv_mem_monitor(&mon);
  ESP_LOGI("MEM", "Memory:  used: %6d (%3d %%), frag: %3d %%, biggest free: %6d",
         (int)mon.total_size - mon.free_size, mon.used_pct, mon.frag_pct,
         (int)mon.free_biggest_size);
If you find there is enough memory returned by the LVGL memory check functions. I would suspect you have a stack overflow or some other memory corruption issue. We might need to see a bit more of your code to help diagnose that sort of problem…
I hope that helps.
Kind Regards,
Pete
