Hi, I’m new to LVGL. I am testing the simulator on VScode and the I’m trying the line chart example. The line chart works perfectly when I show all 10 points, but when I comment out a point, it seems to miss the point before the last point I commented out. How I do resolve this issue?
VScode
V8.0
To get the line chart to show all the dots I want to show
I have commented out the last dot but the second last dot doesn’t show. It works fine when all 10 dots are used.
void lv_example_chart_1(void)
/*Create a chart*/
lv_obj_t * chart;
chart = lv_chart_create(lv_scr_act());
lv_obj_set_size(chart, 200, 150);
lv_obj_center(chart);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE); /*Show lines and points too*/
/*Add two data series*/
lv_chart_series_t * ser2 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_SECONDARY_Y);
/*Directly set points on 'ser2'*/
ser2->y_points[0] = 90;
ser2->y_points[1] = 70;
ser2->y_points[2] = 65;
ser2->y_points[3] = 65;
ser2->y_points[4] = 65;
ser2->y_points[5] = 65;
ser2->y_points[6] = 65;
ser2->y_points[7] = 65;
ser2->y_points[8] = 65;
//ser2->y_points[9] = 65;
lv_chart_refresh(chart); /*Required after direct set*/
As shown, the ninth point doesn’t show even though there is supposed to be data.
