There is the keyboard component in LVGL.
But in documentation I did not found how to change keyboard map on clicking the button.
The idea is to make 4 keyboard maps (2 languages with lowercase and uppercase, total 4 layouts) and change them when clicking the button.
P.S. I use LVGL version 8.3 adn ESP32, but it does not matter.
How can I call it on pressing Shift or language change button?
I try not to set
//lv_keyboard_set_textarea(keyb, message_text_input);
but add letters into message_text_input when user press or long press the button on the matrix except Shift (in my project button # 14)
static void cb_keyboard(lv_event_t * e){
if(code == LV_EVENT_PRESSED | LV_EVENT_LONG_PRESSED){
uint16_t bt = lv_keyboard_get_selected_btn(keyb);
if (bt == 14){
Serial.println("Shift"); //I will try lv_keyboard_set_mode(kb, mode);
} else{
const char * txt = lv_keyboard_get_btn_text(keyb, bt);
lv_textarea_add_text(message_text_input, txt);
but it does not work.
Maybe I need to use
LV_EVENT_VALUE_CHANGED ?
