Keyboard style initial don't work
I try to make my code into several blocks to make it more clear to understand. So I create a function to initial my keyboard style. Then I put the funciton into another file, but it can’t work.
What do you experience?
Give a detailed description. “It doesn’t work” is not enough information for us to diagnose the issue.
What do you expect?
To make code more clear.
version A, this version achieve my expect and is an original version.
static lv_style_t style_kb;
static lv_style_t style_kb_rel;
static lv_style_t style_kb_pr;
static void create_keyboard(lv_obj_t* parent)
    /* 键盘样式 */
    //KeyBoard_Style_Init();
    lv_style_copy(&style_kb, &lv_style_plain);
    style_kb.body.opa = LV_OPA_70;
    style_kb.body.main_color = lv_color_hex3(0x333);
    style_kb.body.grad_color = lv_color_hex3(0x333);
    style_kb.body.padding.left = 0;
    style_kb.body.padding.right = 0;
    style_kb.body.padding.top = 0;
    style_kb.body.padding.bottom = 0;
    style_kb.body.padding.inner = 0;
    lv_style_copy(&style_kb_rel, &lv_style_plain);
    style_kb_rel.body.opa = LV_OPA_TRANSP;
    style_kb_rel.body.radius = 0;
    style_kb_rel.body.border.width = 1;
    style_kb_rel.body.border.color = LV_COLOR_SILVER;
    style_kb_rel.body.border.opa = LV_OPA_50;
    style_kb_rel.body.main_color = lv_color_hex3(0x333);    /*Recommended if LV_VDB_SIZE == 0 and bpp > 1 fonts are used*/
    style_kb_rel.body.grad_color = lv_color_hex3(0x333);
    style_kb_rel.text.color = LV_COLOR_WHITE;
    lv_style_copy(&style_kb_pr, &lv_style_plain);
    style_kb_pr.body.radius = 0;
    style_kb_pr.body.opa = LV_OPA_50;
    style_kb_pr.body.main_color = LV_COLOR_WHITE;
    style_kb_pr.body.grad_color = LV_COLOR_WHITE;
    style_kb_pr.body.border.width = 1;
    style_kb_pr.body.border.color = LV_COLOR_SILVER;
    keyboard = lv_kb_create(parent, NULL);
    lv_obj_set_size(keyboard, 800, 150);
    lv_obj_align(keyboard, parent, LV_ALIGN_IN_BOTTOM_MID, 0, -10);
    lv_kb_set_style(keyboard, LV_KB_STYLE_BG, &style_kb);
    lv_kb_set_style(keyboard, LV_KB_STYLE_BTN_REL, &style_kb_rel);
    lv_kb_set_style(keyboard, LV_KB_STYLE_BTN_PR, &style_kb_pr);
    lv_obj_set_event_cb(keyboard, keyboard_event_cb);
    /* 隐藏键盘,只有在选中文本框的时候才打开键盘 */
    lv_obj_set_hidden(keyboard, true);
version B, I create a function “KeyBoard_Style_Init()” to initial keyboard style, but put it in another file, just call A.c, and give the API interface in the A.h, also, the static variate put into the A.h
bool KeyBoard_Style_Init(void)
then the code change to like this
    /* 键盘样式 */
I think it the same to version A, but it don’t work.
If possible, add screenshots and/or videos about the current issue.
I may find the problem. If the static variate should turn to global variate.
Does this mean you solved the issue?
