Hello, you need to slide left and right in the list in the tabview page. In order to use the tabview, you can also turn the page. I use lv_obj_set_drag_parent() and nothing happens. How can I implement it?
Please fill the template to provide enough information to investigate your issue.
> ## Important: posts that do not use this template will be ignored or closed.
> ## Before posting
> - Get familiar with [Markdown](https://forum.lvgl.io/t/get-familiar-with-markdown/403) to format and structure your post
> - Be sure to update [lvgl](https://github.com/littlevgl/lvgl) from the latest version from the `master` branch.
> - Be sure you have checked the relevant part of the [documentation](https://docs.littlevgl.com/en/html/index.html). **We will not respond in detail to posts where you haven't read the relevant documentation.**
> - If applicable use the [Simulator](https://docs.littlevgl.com/en/html/get-started/pc-simulator.html) to eliminate hardware related issues.
> *Delete this section if you read and applied the mentioned points.*
## Description
### What MCU/Processor/Board and compiler are you using?
### What do you want to achieve?
### What have you tried so far?
## Code to reproduce
```c
