mhel
June 11, 2019, 2:17am
21
I decided to try the 5.3 release, unfortunately it’s the same thing. There’s some tearing on the display.
It’s slower then freezes.
I like the default font on dev-6.0 I think I’ll revert back to that. And maybe I’ll just stick to the default
preloader. I’ll give it a rest for now, a bit late.
Thanks guys.
@mhel Please share our code, maybe there is small ltypo in it.
mhel
June 11, 2019, 2:26pm
23
There’s really nothing to it. I think.
LV_IMG_DECLARE(img1)
LV_IMG_DECLARE(img2)
LV_IMG_DECLARE(img3)
LV_IMG_DECLARE(img4)
LV_IMG_DECLARE(img5)
static void img_looper(lv_task_t *param) {
(void)param;
lv_img_dsc_t *const my_images[] = {
&img1,
&img2,
&img3,
&img4,
&img5
static int img_index = 0;
lv_obj_t * img_loop = lv_img_create(lv_scr_act(), NULL); /*Create an image object*/
lv_img_set_src(img_loop, my_images[img_index]); /* Set the next image */
img_index++;
if(img_index == 5)
img_index = 0;
int main(void)
/*LittlevGL init*/
/*Linux frame buffer device init*/
fbdev_init();
static lv_color_t buf_1[LV_HOR_RES_MAX * LV_VER_RES_MAX]; /*A screen sized buffer*/
static lv_color_t buf_2[LV_HOR_RES_MAX * LV_VER_RES_MAX]; /*An other screen sized buffer*/
lv_disp_buf_init(&disp_buf, buf_1, buf_2, LV_HOR_RES_MAX * LV_VER_RES_MAX); /*Initialize the display buffer*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 160;
disp_drv.ver_res = 128;
/*Set a display buffer*/
disp_drv.buffer = &disp_buf;
lv_style_scr.body.main_color = LV_COLOR_BLACK;
lv_style_scr.body.grad_color = LV_COLOR_BLACK;
lv_task_create( coin_animate, 200, LV_TASK_PRIO_LOWEST, NULL );
while(1) {
lv_task_handler();
usleep(5000);
fbdev_exit();
return 0;
mhel
June 11, 2019, 2:30pm
24
Oh and I had to learn pthread creation so could have the tick handler separated.
static void *thr_tick_inc(void * data)
struct timespec sleep_tm = {0,5000000U};
(void)data;
while(1) {
nanosleep( &sleep_tm, NULL );
lv_tick_inc(5);
return NULL;
@mhel You can use usleep in the pthread instead, it’s a lot simpler. It’s deprecated but for your use case I don’t think it will have any problems.
Also please use Markdown for showing your code (i.e. prefix with “```c” and end with “````”, minus the quotes).
Ah, I see the problem. You are creating a new image object each time. Eventually you’ll run out of memory.
You needed to create the image object once , in the main function.
mhel
June 11, 2019, 3:07pm
27
Thanks.
With dev-6.0 how can I pass the img object as a parameter?
In 5.3 I know how to pass a void pointer, but it’s not the same on 6.0.
BTW thanks for editing the code display I tried to edit it but didn’t know the code.
Create the task the same way you did in 5.3. Then in img_looper:
static void img_looper(lv_task_t *task)
lv_obj_t *img = (lv_obj_t *)task->user_data;
should work.
mhel
June 11, 2019, 3:33pm
29
Yey it works!
Thanks so much. It’s always good to learn something new everyday
Hopefully complete solution, for the benefit of others who may read this post:
#define NUM_IMAGES 5
lv_img_dsc_t *const my_images[NUM_IMAGES] = {
&img1,
&img2,
&img3,
&img4,
&img5
static lv_obj_t *img_loop; /*To be created in the main() function*/
(void)param;
img_index++;
if(img_index == 5)
img_index = 0;
int main(void)
lv_task_create( img_looper, 200, LV_TASK_PRIO_LOWEST, NULL );
You need to create the img_obj once somewhere else in the code.
