Image from SD card without proper FS driver
In some cases I am using LVGL on platforms that have preety basic fs support and do not implement fseek and ftell. But lvgl needs ftell and fseek acording to docs. Can i read it with my code and just pass readed buffer to lv_img_set_src?
I am using lvgl as a bootloader GUI. Bootloader is based on little kernel
latest mastert
Displaying image with this partitialy working driver.
unsigned char *buf;
    filehandle *entry_file_handle = NULL;
    fs_mount("/boot", "ext2", "mmc1p1");
    off_t entry_file_size = fs_get_file_size("/boot/test");
    buf = malloc(entry_file_size + 1);
    fs_open_file("/boot/test", &entry_file_handle);
    fs_read_file(entry_file_handle, buf, 0, entry_file_size);
    fs_close_file(entry_file_handle);
    list_btn = lv_list_add_btn(list1,  buf, "\nExtras\n");
It is possible to construct an image descriptor (which contains a header plus the data size and pointer) in memory and then use lv_img_set_src(obj, img_dsc); to display it. I’ve used it to the download an image over HTTP and display that in LVGL.
If you store the image as a .BIN file using the Image Converter then the first 4 bytes of the image will already contain the image header and the remainder is the pixel data. If you use another file-type you need to construct a header and point it to a pixel data buffer.
e.g. if image.bin contains:
[ header ]      +         [ pixel data ]
^lv_img_header_t struct   ^filesize - sizeof(lv_img_header_t)
In memory you need an img_dsc which is a struct that consists of 3 fields:
    lv_img_header_t header;    // read sizeof(lv_img_header_t) from the file
    uint32_t data_size;        // filesize - sizeof(lv_img_header_t)
    const uint8_t * data;      // pointer to a buffer with the rest of the file
The general flow (untested and without error checking) would be something like this:
    off_t header_len      = sizeof(lv_img_header_t);          // file header struct
    off_t buf_len         = entry_file_size - header_len;     // file size minus header size
    lv_img_dsc_t* img_dsc = malloc(sizeof(lv_img_dsc_t));     // image descriptor struct
    unsigned char *buf    = malloc(buf_len);                  // pixel data only
    fs_read_file(entry_file_handle, img_dsc, 0, header_len);  // read header struct (first 4 bytes)
    fs_read_file(entry_file_handle, buf , 0, buf_len);        // read pixel data (remainder)
    // img_dsc->header should already be fine. Print its contents to make sure...
    img_dsc->data      = buf;
    img_dsc->data_size = buf_len;
Now, if the image were to be a .PNG file then the buffer would contain the whole file and you would set the header fields manually:
    img_dsc->header.cf          = LV_IMG_CF_RAW_ALPHA;
    img_dsc->header.always_zero = 0;
    img_dsc->header.reserved    = 0;
    img_dsc->header.w           = buf[19] + (buf[18] << 8);  // extract image dimensions from the data
    img_dsc->header.h           = buf[23] + (buf[22] << 8);
    img_dsc->data_size          = entry_file_size;
Thanks, will try and report result.
