I’m struggling with a png image that I can’t freeze in my lv_micropython built.
Is it possible to do it?
I tried to generate a C array with online tools but I don’t know how to use it with micropython instead of lv.img.decoder_create()
Thank you for your help
Hi @Patoche5150!
Yes it’s possible.
According to the docs you need to declare a C variable of type lv_img_dsc_t
and populate it statically.
You can use the online image converter to generate a C file with a static lv_img_dsc_t
variable that represents your image.
To use it in Micropython you need to rebuild lv_micropython:
- Put your C file with the image variable somewhere under
lib/lv_bindings/lvgl/src/
(or its subdirectories) so the Makefile could find it. Alternatively you can change the Makefile and add your C file under SRC_MOD
- To make the image available in Micropython, it needs to be declared (as
extern
) in some header file that is processed by the LVGL-Micropython-binding script. You can add the extern to lvgl.h or to any file that is included by it, such as lv_conf.h
After these steps, your image should be available in Micropython under the lvgl module.
You can create an image with lv.img_create
and call img.set_src
with your image as an argrument.
Hi @amirgon,
thank you so much for your response.
I used the online image converter, it is ok, I generated my C file.
Rebuild lv_micropython is also ok, no problem.
But I don’t know how to declare the image file as extern in a header file.
It’s probably easy but I am not used with that. Could you give me the good command line for that ?
Thank you
Yes, you simply need to add a line to some header file, something like:
extern const lv_img_dsc_t my_image;
You can add it, for example, at the end of lvgl.h before the: #ifdef __cplusplus} #endif.
Then build lv_micropython. You only need this line.
my_image
above is the name of your image. You can find it at the end of your generated image file.
You would see there something like:
const lv_img_dsc_t my_image = {
.header.always_zero = 0,
.header.w = 441,
.header.h = 428,
.data_size = 188748 * LV_COLOR_SIZE / 8,
.header.cf = LV_IMG_CF_TRUE_COLOR,
.data = my_image_map,
