ILI9341 + ESP IDF with LVGL
I solved,
The solutions code:
lcd.c
#include <stdio.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "esp_timer.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_vendor.h"
#include "esp_lcd_panel_ops.h"
#include "driver/gpio.h"
#include "driver/spi_master.h"
#include "esp_err.h"
#include "esp_log.h"
#include "lvgl.h"
#include "nvs_flash.h"
#include "esp_lcd_ili9341.h"
#include "esp_lcd_touch_xpt2046.h"
#include "touch.h"
#include "hardware.h"
#include "lcd.h"
#include "ui.h"
static const char *TAG = "LCD:";
esp_lcd_touch_handle_t tp_Handle;
static SemaphoreHandle_t lvgl_mux = NULL;
static bool flush_ready_cb(esp_lcd_panel_io_handle_t panel_io, esp_lcd_panel_io_event_data_t *edata, void *user_ctx){
        lv_disp_drv_t *disp_driver = (lv_disp_drv_t *)user_ctx;
        lv_disp_flush_ready(disp_driver);
        return false;
static void flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map){
        esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t) drv->user_data;
        int offsetx1 = area->x1;
        int offsetx2 = area->x2;
        int offsety1 = area->y1;
        int offsety2 = area->y2;
        esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, color_map);
static void touch_cb(lv_indev_drv_t * drv, lv_indev_data_t * data){
        uint16_t touchpad_x[1] = {0};
        uint16_t touchpad_y[1] = {0};
        uint8_t touchpad_cnt = 0;
        esp_lcd_touch_read_data(drv->user_data);
        bool touchpad_pressed = esp_lcd_touch_get_coordinates(drv->user_data, touchpad_x, touchpad_y, NULL, &touchpad_cnt, 1);
        if (touchpad_pressed && touchpad_cnt > 0) {
            data->point.x = touchpad_x[0];
            data->point.y = touchpad_y[0];
            data->state = LV_INDEV_STATE_PRESSED;
        } else {
            data->state = LV_INDEV_STATE_RELEASED;
static void example_increase_lvgl_tick(void *arg){
        lv_tick_inc(EXAMPLE_LVGL_TICK_PERIOD_MS);
bool example_lvgl_lock(int timeout_ms){
        const TickType_t timeout_ticks = (timeout_ms == -1) ? portMAX_DELAY : pdMS_TO_TICKS(timeout_ms);
        return xSemaphoreTakeRecursive(lvgl_mux, timeout_ticks) == pdTRUE;
void example_lvgl_unlock(void){
    xSemaphoreGiveRecursive(lvgl_mux);
static void port_task(void *arg){
        ESP_LOGI(TAG, "Starting LVGL task");
        uint32_t task_delay_ms = EXAMPLE_LVGL_TASK_MAX_DELAY_MS;
        while (1) {
            if (example_lvgl_lock(-1)) {
                task_delay_ms = lv_timer_handler();
                example_lvgl_unlock();
            if (task_delay_ms > EXAMPLE_LVGL_TASK_MAX_DELAY_MS) {
            } else if (task_delay_ms < EXAMPLE_LVGL_TASK_MIN_DELAY_MS) {
                task_delay_ms = EXAMPLE_LVGL_TASK_MIN_DELAY_MS;
            vTaskDelay(pdMS_TO_TICKS(task_delay_ms));
void f_setupDisplay(){
            static lv_disp_draw_buf_t disp_buf; // contains internal graphic buffer(s) called draw buffer(s)
            static lv_disp_drv_t disp_drv;      // contains callback functions
            ESP_LOGI(TAG, "Turn off LCD backlight");
            gpio_config_t bk_gpio_config = {.mode = GPIO_MODE_OUTPUT,.pin_bit_mask = 1ULL << EXAMPLE_PIN_NUM_BK_LIGHT};
            ESP_ERROR_CHECK(gpio_config(&bk_gpio_config));
            ESP_LOGI(TAG, "Initialize SPI bus");
            spi_bus_config_t buscfg = {
                    .sclk_io_num = EXAMPLE_PIN_NUM_SCLK,
                    .mosi_io_num = EXAMPLE_PIN_NUM_MOSI,
                    .miso_io_num = EXAMPLE_PIN_NUM_MISO,
                    .quadwp_io_num = -1,
                    .quadhd_io_num = -1,
                    .max_transfer_sz = CONFIG_LCD_HRES * 80 * sizeof(uint16_t),
            ESP_ERROR_CHECK(spi_bus_initialize(LCD_HOST, &buscfg, SPI_DMA_CH_AUTO));
            ESP_LOGI(TAG, "Install panel IO");
            esp_lcd_panel_io_handle_t io_handle = NULL;
            esp_lcd_panel_io_spi_config_t io_config = {
                    .dc_gpio_num = EXAMPLE_PIN_NUM_LCD_DC,
                    .cs_gpio_num = EXAMPLE_PIN_NUM_LCD_CS,
                    .pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
                    .lcd_cmd_bits = EXAMPLE_LCD_CMD_BITS,
                    .lcd_param_bits = EXAMPLE_LCD_PARAM_BITS,
                    .spi_mode = 0,
                    .trans_queue_depth = 10,
                    .on_color_trans_done = flush_ready_cb,
                    .user_ctx = &disp_drv,
            ESP_ERROR_CHECK(esp_lcd_new_panel_io_spi((esp_lcd_spi_bus_handle_t)LCD_HOST, &io_config, &io_handle));
            esp_lcd_panel_handle_t panel_handle = NULL;
            esp_lcd_panel_dev_config_t panel_config = {
                    .reset_gpio_num = EXAMPLE_PIN_NUM_LCD_RST,
                    .rgb_ele_order = LCD_RGB_ELEMENT_ORDER_BGR,
                    .bits_per_pixel = 16,
            ESP_LOGI(TAG, "Install ILI9341 panel driver");
            ESP_ERROR_CHECK(esp_lcd_new_panel_ili9341(io_handle, &panel_config, &panel_handle));
            ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
            ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
            ESP_ERROR_CHECK(esp_lcd_panel_mirror(panel_handle, true, false));
            ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
            tp_Handle = InitTouchPanel();
            ESP_LOGI(TAG, "Turn on LCD backlight");
            gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, EXAMPLE_LCD_BK_LIGHT_ON_LEVEL);
            ESP_LOGI(TAG, "Initialize LVGL library");
            lv_init();
            // alloc draw buffers used by LVGL
            // it's recommended to choose the size of the draw buffer(s) to be at least 1/10 screen sized
            lv_color_t *buf1 = heap_caps_malloc(CONFIG_LCD_HRES * 20 * sizeof(lv_color_t), MALLOC_CAP_DMA);
            assert(buf1);
            lv_color_t *buf2 = heap_caps_malloc(CONFIG_LCD_HRES * 20 * sizeof(lv_color_t), MALLOC_CAP_DMA);
            assert(buf2);
            lv_disp_draw_buf_init(&disp_buf, buf1, buf2, CONFIG_LCD_HRES * 20);
            ESP_LOGI(TAG, "Register display driver to LVGL");
            lv_disp_drv_init(&disp_drv);
            disp_drv.hor_res = CONFIG_LCD_HRES;
            disp_drv.ver_res = CONFIG_LCD_VRES;
            disp_drv.flush_cb = flush_cb;
            disp_drv.draw_buf = &disp_buf;
            disp_drv.user_data = panel_handle;
            lv_disp_t *disp = lv_disp_drv_register(&disp_drv);
            ESP_LOGI(TAG, "Install LVGL tick timer");
            const esp_timer_create_args_t lvgl_tick_timer_args = {.callback = &example_increase_lvgl_tick,.name = "lvgl_tick"};
            esp_timer_handle_t lvgl_tick_timer = NULL;
            ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
            ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, EXAMPLE_LVGL_TICK_PERIOD_MS * 1000));
            static lv_indev_drv_t indev_drv;    // Input device driver (Touch)
            lv_indev_drv_init(&indev_drv);
            indev_drv.type = LV_INDEV_TYPE_POINTER;
            indev_drv.disp = disp;
            indev_drv.read_cb = touch_cb;
            indev_drv.user_data = tp_Handle;
            lv_indev_drv_register(&indev_drv);
            lvgl_mux = xSemaphoreCreateRecursiveMutex();
            assert(lvgl_mux);
            ESP_LOGI(TAG, "Create LVGL task");
            xTaskCreate(port_task, "LVGL", EXAMPLE_LVGL_TASK_STACK_SIZE, NULL, EXAMPLE_LVGL_TASK_PRIORITY, NULL);
            ui_init();
touch.c
#include <stdio.h>
#include <stdlib.h>
#include "touch.h"
#define TAG "TouchPanel"
static touch_calibration_t touch_calibration = {0, CONFIG_LCD_HRES, 0, CONFIG_LCD_VRES};
esp_lcd_touch_handle_t InitTouchPanel(void);
void calibrate_touch_screen(esp_lcd_touch_handle_t tp) {
        uint16_t x[1], y[1], strength[1];
        uint8_t point_num = 0;
        uint16_t x_sum = 0, y_sum = 0;
        const int calibration_points = 5;
        uint16_t x_min, y_min, x_max, y_max;  // Declaração de x_min, y_min, x_max, e y_max
        ESP_LOGI(TAG, "Calibrating touch screen...");
        ESP_LOGI(TAG, "Touch the top-left corner %d times", calibration_points);
        x_sum = 0;
        y_sum = 0;
        for (int i = 0; i < calibration_points; i++) {
            point_num = 0;
            while (point_num == 0) {
                esp_lcd_touch_read_data(tp);
                if (esp_lcd_touch_get_coordinates(tp, x, y, strength, &point_num, 1)) {
                    x_sum += x[0];
                    y_sum += y[0];
                    ESP_LOGI(TAG, "Sample %d: X: %" PRIu16 " Y: %" PRIu16, i + 1, x[0], y[0]);
                vTaskDelay(pdMS_TO_TICKS(100));
            vTaskDelay(pdMS_TO_TICKS(500));  // Pequena pausa para o próximo toque
        x_min = x_sum / calibration_points;
        y_min = y_sum / calibration_points;
        ESP_LOGI(TAG, "Averaged top-left X: %" PRIu16 " Y: %" PRIu16, x_min, y_min);
        ESP_LOGI(TAG, "Touch the top-right corner %d times", calibration_points);
        x_sum = 0;
        y_sum = 0;
            point_num = 0;
                    x_sum += x[0];
                    y_sum += y[0];
        x_max = x_sum / calibration_points;
        ESP_LOGI(TAG, "Averaged top-right X: %" PRIu16 " Y: %" PRIu16, x_max, y_min);
        ESP_LOGI(TAG, "Touch the bottom-left corner %d times", calibration_points);
        x_sum = 0;
        y_sum = 0;
            point_num = 0;
                    x_sum += x[0];
                    y_sum += y[0];
        y_max = y_sum / calibration_points;  // Corrigido: y_max agora é declarado corretamente
        ESP_LOGI(TAG, "Averaged bottom-left X: %" PRIu16 " Y: %" PRIu16, x_min, y_max);
        ESP_LOGI(TAG, "Touch the bottom-right corner %d times", calibration_points);
        x_sum = 0;
        y_sum = 0;
            point_num = 0;
                    x_sum += x[0];
                    y_sum += y[0];
        ESP_LOGI(TAG, "Averaged bottom-right X: %" PRIu16 " Y: %" PRIu16, x_max, y_max);
        touch_calibration.x_min = x_min;
        touch_calibration.y_min = y_min;
        touch_calibration.x_max = x_max;
        touch_calibration.y_max = y_max;
        ESP_LOGI(TAG, "Touch screen calibration complete.");
uint16_t map(uint16_t n, uint16_t in_min, uint16_t in_max, uint16_t out_min, uint16_t out_max){
        uint16_t value = (n - in_min) * (out_max - out_min) / (in_max - in_min);
        return (value < out_min) ? out_min : ((value > out_max) ? out_max : value);
void process_coordinates(esp_lcd_touch_handle_t tp, uint16_t *x, uint16_t *y, uint16_t *strength, uint8_t *point_num, uint8_t max_point_num) {
        *x = map(*x, touch_calibration.x_min, touch_calibration.x_max, 0, CONFIG_LCD_HRES);
        *y = map(*y, touch_calibration.y_min, touch_calibration.y_max, 0, CONFIG_LCD_VRES);
esp_lcd_touch_handle_t InitTouchPanel(void){
        esp_lcd_panel_io_handle_t tp_io_handle = NULL;
        static esp_lcd_touch_handle_t tp = NULL;
        const esp_lcd_panel_io_spi_config_t tp_io_config = { .cs_gpio_num = CONFIG_TOUCH_CS,
            .dc_gpio_num = CONFIG_TOUCH_DC,
            .spi_mode = 0,
            .pclk_hz = CONFIG_TOUCH_CLOCK_HZ,
            .trans_queue_depth = 3,
            .on_color_trans_done = NULL,
            .user_ctx = NULL,
            .lcd_cmd_bits = 8,
            .lcd_param_bits = 8,
            .flags = { .dc_low_on_data = 0, .octal_mode = 0, .sio_mode = 0, .lsb_first = 0, .cs_high_active = 0 } };
        esp_lcd_touch_config_t tp_cfg = {.x_max = CONFIG_LCD_HRES,
                                    .y_max = CONFIG_LCD_VRES,
                                    .rst_gpio_num = CONFIG_TOUCH_RST,
                                    .int_gpio_num = CONFIG_TOUCH_IRQ,
                                    .levels = {.reset = 0, .interrupt = 0},
                                    .flags ={
                                            .swap_xy = 0,
                                            .mirror_x = 0,
                                            .mirror_y = 0,
                                    .process_coordinates = process_coordinates,
                                    .interrupt_callback = NULL};
        ESP_ERROR_CHECK(esp_lcd_new_panel_io_spi((esp_lcd_spi_bus_handle_t)CONFIG_TOUCH_SPI, &tp_io_config, &tp_io_handle));
        ESP_ERROR_CHECK(esp_lcd_touch_new_spi_xpt2046(tp_io_handle, &tp_cfg, &tp));
        ESP_LOGI(TAG, "Touch Inicializado");
        InitTouchPanelWithCalibration(tp);
        return tp;
void InitTouchPanelWithCalibration(esp_lcd_touch_handle_t tp) {
        if (!load_calibration_data(&touch_calibration)) {
            calibrate_touch_screen(tp);
            save_calibration_data(&touch_calibration);
        } else {
            ESP_LOGI(TAG, "Calibration data loaded from NVS");
void save_calibration_data(touch_calibration_t *calibration) {
        nvs_handle_t nvs_handle;
        esp_err_t err = nvs_open("storage", NVS_READWRITE, &nvs_handle);
        if (err != ESP_OK) {
            ESP_LOGE(TAG, "Error opening NVS handle!");
            return;
        err = nvs_set_u16(nvs_handle, "x_min", calibration->x_min);
        if (err != ESP_OK) ESP_LOGE(TAG, "Failed to save x_min");
        err = nvs_set_u16(nvs_handle, "x_max", calibration->x_max);
        if (err != ESP_OK) ESP_LOGE(TAG, "Failed to save x_max");
        err = nvs_set_u16(nvs_handle, "y_min", calibration->y_min);
        if (err != ESP_OK) ESP_LOGE(TAG, "Failed to save y_min");
        err = nvs_set_u16(nvs_handle, "y_max", calibration->y_max);
        if (err != ESP_OK) ESP_LOGE(TAG, "Failed to save y_max");
        err = nvs_commit(nvs_handle);
            ESP_LOGE(TAG, "Failed to commit changes!");
        nvs_close(nvs_handle);
bool load_calibration_data(touch_calibration_t *calibration) {
        esp_err_t err = nvs_open("storage", NVS_READONLY, &nvs_handle);
            return false;
        err = nvs_get_u16(nvs_handle, "x_min", &calibration->x_min);
            ESP_LOGE(TAG, "Failed to load x_min");
            return false;
        err = nvs_get_u16(nvs_handle, "x_max", &calibration->x_max);
            ESP_LOGE(TAG, "Failed to load x_max");
            return false;
        err = nvs_get_u16(nvs_handle, "y_min", &calibration->y_min);
            ESP_LOGE(TAG, "Failed to load y_min");
            return false;
        err = nvs_get_u16(nvs_handle, "y_max", &calibration->y_max);
            ESP_LOGE(TAG, "Failed to load y_max");
            return false;
        return true;
hardware.h
#pragma once
#define CONFIG_TOUCH_CLOCK_HZ ESP_LCD_TOUCH_SPI_CLOCK_HZ
#define CONFIG_TOUCH_SPI      SPI2_HOST
#define CONFIG_TOUCH_CS       (gpio_num_t) GPIO_NUM_33
#define CONFIG_TOUCH_DC       (gpio_num_t) GPIO_NUM_NC
#define CONFIG_TOUCH_RST      (gpio_num_t) GPIO_NUM_NC
#define CONFIG_TOUCH_IRQ      (gpio_num_t) GPIO_NUM_36 /* GPIO_NUM_36 */
// #define TOUCH_Y_RES_MIN 15
// #define TOUCH_Y_RES_MAX 218
#define CONFIG_LCD_HRES     240
#define CONFIG_LCD_VRES     320
#define LCD_HOST  SPI2_HOST
//////////////////// Please update the following configuration according to your LCD spec //////////////////////////////
#define EXAMPLE_LCD_PIXEL_CLOCK_HZ     (20 * 1000 * 1000)
#define EXAMPLE_LCD_BK_LIGHT_ON_LEVEL  1
#define EXAMPLE_LCD_BK_LIGHT_OFF_LEVEL !EXAMPLE_LCD_BK_LIGHT_ON_LEVEL
#define EXAMPLE_PIN_NUM_SCLK           14
#define EXAMPLE_PIN_NUM_MOSI           13
#define EXAMPLE_PIN_NUM_MISO           12
#define EXAMPLE_PIN_NUM_LCD_DC         2
#define EXAMPLE_PIN_NUM_LCD_RST        -1
#define EXAMPLE_PIN_NUM_LCD_CS         15
#define EXAMPLE_PIN_NUM_BK_LIGHT       27
#define EXAMPLE_PIN_NUM_TOUCH_CS       33
#define EXAMPLE_LCD_CMD_BITS           8
#define EXAMPLE_LCD_PARAM_BITS         8
#define EXAMPLE_LVGL_TICK_PERIOD_MS    2
#define EXAMPLE_LVGL_TASK_MAX_DELAY_MS 500
#define EXAMPLE_LVGL_TASK_MIN_DELAY_MS 1
#define EXAMPLE_LVGL_TASK_STACK_SIZE   (4 * 1024)
#define EXAMPLE_LVGL_TASK_PRIORITY     2
and
idf_component.yml
dependencies:
  idf: ">=4.4"
  lvgl/lvgl: "~8.3.0"
  esp_lcd_ili9341: "^1.0"
  esp_lcd_gc9a01: "^1.0"
  esp_lcd_touch_stmpe610: "^1.0"
  atanisoft/esp_lcd_touch_xpt2046: "~1.0.1"
