I am following a tutorial on LVGL academy about LVGL tasks with RTOS. The tutor used a FreeRTOS header file in his example but he ran the build on an actual board rather than the simulator.
Eclipse IDE
I want to recreate the tutorial on the pc simulator and I am unable to access FreeRTOS header files and its required sub header files.
Is it possible to even use FreeRTOS headers in the sim? There isn’t much info regarding sim + RTOS in the forum/ docs.
I’m a fairly new beginner and would appreciate any clarification.
- I managed to setup the esp-idf environment within eclipse. Can’t get it to work even though the paths are all correct. I can build esp projects fine.
- I tried manually setting the import paths to my esp idf directory but it didn’t work as it needed many more sub header files.
None
None
