How to set the width of an image moving leftwards
Hello. I have an image whose width I would like to change during an animation. The position remains the same, but I would like the width to increase in the leftwards direction. I can easily do this animation with the width increasing in the right direction using lv_obj_set_width, but can’t figure out how I can mirror this behavior and have the image increase in width from right to left as the image remains in the same position.
Similarly, is there a way to have a “window” of an image displayed? As in, the right and left bounds of the viewable image are not at either the left or right edges of the image itself.
STM32G4 and custom HW. GDB compiler
7.6.1
I’ve messed around with the lv_obj_align, lv_obj_set_width, and lv_img_set_offset_x functions but can’t find a combination that works as desired.
Thanks,
Rob
Did you use lv_obj_realign() after changing the width of the object?
