Id like to set the scrollbar properties in a tabview.
Ive tried adapting the content from here
https://docs.lvgl.io/master/overview/scroll.html
But no luck
Simulator
8.3
As description
/*Set scrollbar props*/
/*Remove the style of scrollbar to have clean start*/
lv_obj_remove_style(lv_tabview_get_content(tv), NULL, LV_PART_SCROLLBAR | LV_STATE_ANY);
/*Create a transition the animate the some properties on state change*/
static const lv_style_prop_t props[] = {LV_STYLE_BG_OPA, LV_STYLE_WIDTH, 0};
/*Create a style for the scrollbars*/
static lv_style_transition_dsc_t trans;
lv_style_transition_dsc_init(&trans, props, lv_anim_path_linear, 200, 0, NULL);
static lv_style_t _style;
lv_style_init(&_style);
lv_style_set_width(&_style, 4); /*Width of the scrollbar*/
lv_style_set_pad_right(&_style, 5); /*Space from the parallel side*/
lv_style_set_pad_top(&_style, 5); /*Space from the perpendicular side*/
lv_style_set_radius(&_style, 2);
lv_style_set_bg_opa(&_style, LV_OPA_70);
lv_style_set_bg_color(&_style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_border_color(&_style, lv_palette_darken(LV_PALETTE_BLUE, 3));
lv_style_set_border_width(&_style, 2);
lv_style_set_shadow_width(&_style, 8);
lv_style_set_shadow_spread(&_style, 2);
lv_style_set_shadow_color(&_style, lv_palette_darken(LV_PALETTE_BLUE, 1));
lv_style_set_transition(&_style, &trans);
/*Make the scrollbars wider and use 100% opacity when scrolled*/
static lv_style_t style_scrolled;
lv_style_init(&style_scrolled);
lv_style_set_width(&style_scrolled, 8);
lv_style_set_bg_opa(&style_scrolled, LV_OPA_COVER);
lv_obj_add_style(lv_tabview_get_content(tv), &_style, LV_PART_SCROLLBAR);
lv_obj_add_style(lv_tabview_get_content(tv), &style_scrolled, LV_PART_SCROLLBAR | LV_STATE_SCROLLED);
Thanks!!
