Hi @kisvegabor, on my project lvgl has the following functions:
1. Gui window management, buffer size **800X600**
2. Draw the icon or text fill on the camera display, buffer size is **800X50**
Because there is not enough memory on my device, so when switch between function 1 and function 2, I need to exit lvgl each time, and then reinit lvgl with the new buff size.
If LV_ MEM_CUSTOM set 1, how safely release the resource of each lvgl during switching?
I look forward to your reply to the above questions, thank you ver much!
I use lv_disp_remove when exit lvgl, the position B’s memory is about 5K bigger then position A.
show mem //A
use lvgl
exit lvgl
show mem //B
Sorry, the version of lvgl is V8.3.3.
Hi @kisvegabor, do you know how to safety exit lvgl? I’m waiting for you answer, thanks.
Unfortunately we have no good option now to release all resources with MEM_CUSTOM 1
. If the built-in memory manager is used we can easily re-init it and you will have a new empty memory.
So I think the simplest would be to use the internal memory manager (MEM_CUSTOM 0). Is it possible?
But do you really need to reinit the whole LVGL? Isn’t deleting all the screens enough?
I’m very glad get your reply.
Yes, I need to release lvgl resource, because the frame size of two mode is diffrent.
I will try with LV_MEM_CUSTOM=0 used lv_disp_remove first, thank you very much!
You can also modify the display’s resolution by calling lv_disp_drv_update
Sorry, I’m late to answer you, because currently I’m busy in project developing.
Is this code corrent? I use " lv_disp_drv_update" like below, it will crash on my board.
void lv_port_disp_reinit(int hor_size, int ver_size)
/* Example for 2) */
static lv_disp_draw_buf_t draw_buf_dsc_2;
lv_disp_draw_buf_init(&draw_buf_dsc_2, LCD_FRAMME_BUFF_ADDR_1, LCD_FRAMME_BUFF_ADDR_2, hor_size * ver_size); /*Initialize the display buffer*/
static lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = hor_size ;
disp_drv.ver_res = ver_size ;
disp_drv.full_refresh = 0;
disp_drv.direct_mode = 1;
disp_drv.flush_cb = disp_flush;
/*Set a display buffer*/
disp_drv.draw_buf = &draw_buf_dsc_2;
lv_disp_drv_update(lv_disp_get_default(), &disp_drv);
When close lvgl, this task will not run until reopen(1. lv_port_disp_reinit 2. set g_run_step to GUI_RUNNING):
static void _disp_thread_main( void *arg )
while(1)
if(GUI_STOP == g_run_step){
rtos_delay_milliseconds(500);
continue;
bk_gui_disp_lock();
lv_task_handler();
bk_gui_disp_unlock();
rtos_delay_milliseconds(5);
rtos_delete_thread(NULL);
It looks good at first look. Do you see where it crashes?
