how to rewrite the label of a button?
I create a button ,and add a label “button A” to it, then I want to rename the label when I clicked the button, and turn to “btn B”
## Screenshot and/or video
lv_obj_t* btn = lv_btn_create(lv_scr_act(),NULL);
lv_obj_t* label = lv_label_create(btn, NULL);
lv_label_set_text(label, "ButtonA");
btn->user_data = (void*) label;
lv_obj_set_event_cb(btn, [](lv_obj_t*btn, lv_event_t event){
if(event != LV_EVENT_CLICKED) return;
lv_label_set_text((lv_obj_t*)btn->user_data, "ButtonB");
Note that you should almost never modify a structure variable of a LittlevGL object, and instead use the appropriate helper function (lv_obj_set/get_user_data
@TridentTD’s solution should work. Another option is to get the button’s first child object. But this requires the button to only have a label as its child.
