I’m calling lv_win_clean
to remove content added to a lv_win
widget, but it’s only removing element from the window header. In the example below (from the doc), the added label is still present after lv_win_clean
. What did I missed?
7.0.2 (from Zephyr)
remove content added to window
/*Create a window*/
lv_obj_t * win = lv_win_create(lv_scr_act(), NULL);
lv_win_set_title(win, "Window title"); /*Set the title*/
/*Add control button to the header*/
lv_obj_t * close_btn = lv_win_add_btn(win, LV_SYMBOL_CLOSE); /*Add close button and use built-in close action*/
lv_obj_set_event_cb(close_btn, lv_win_close_event_cb);
lv_win_add_btn(win, LV_SYMBOL_SETTINGS); /*Add a setup button*/
/*Add some dummy content*/
lv_obj_t * txt = lv_label_create(win, NULL);
lv_label_set_text(txt, "This is the content of the window\n\n"
"You can add control buttons to\n"
"the window header\n\n"
"The content area becomes\n"
"automatically scrollable is it's \n"
"large enough.\n\n"
" You can scroll the content\n"
"See the scroll bar on the right!");
/* Removing content ? */
lv_win_clean(win);
