How to move between screens without deleting previous screen
I have two screens, a main screen that is very simple and a menu screen that is complex. The menu screen takes over a second to create on my hardware.
I would like to be able to switch between the screens via the load functions.
I would like to avoid deleting the menu_screen due to the time it takes to create it. However, if i do not delete it, I still get event handlers called for the inactive screen.
nRF52840
gcc
8
I would like
If I exit the menu_screen and try to load the main screen, I still get highlight events on the previous menu screen.
lv_scr_load_anim(menu_screen, LV_SCR_LOAD_ANIM_MOVE_LEFT, 1000, 0, false);
lv_scr_load_anim(main_screen, LV_SCR_LOAD_ANIM_MOVE_LEFT, 1000, 0, false);
Is there a way to switch screens without deleting the previous one and disable the event handlers on the inactive display?
My current approach is to lock out the menu screen events via a screen check, but this seems like a poor solution.
static void m_focus_handler(lv_event_t *e)
    lv_obj_t *curr_screen = lv_scr_act();
    if (curr_screen != menu_screen)
        return;
