When “clicking” on the empty space between buttons arranged in a button matrix, I get NULL text in the corresponding handler.
Is there a button matrix property to set, so that clicks always fall onto a button and not on the “background panel”?
Odroid N2, Ubuntu18.04, gcc 8.4.0
Avoid getting NULL text into the button handler, when clicking “outside” a button in a button matrix
Followed the code example for the button matrix
#include "lvgl/lvgl.h"
#include "lv_drivers/display/fbdev.h"
#include "lv_drivers/indev/evdev.h"
#include <stdio.h>
#include <unistd.h>
#define DISP_BUF_SIZE 64*1024UL // If smaller than screen memory, draw will occur in chunks; but if the buffer is not too small, performances are still plenty
#define LV_LOOP_INTERVAL_MS 5
#define GUI_DEBUGMODE
static const char* upperButtonMatrix_map[] = {"1", "2", "3", "4", "5", ""};
static void GUIinit(void)
/*LittlevGL init*/
/*Linux frame buffer device init*/
fbdev_init();
/*Small buffers for LittlevGL to draw the screen's content with double-buffering*/
static lv_color_t buf1[DISP_BUF_SIZE];
static lv_color_t buf2[DISP_BUF_SIZE];
/*Initialize a descriptor for the buffer, with double buffering*/
lv_disp_buf_init(&disp_buf, buf1, buf2, DISP_BUF_SIZE);
/*Initialize and register a display driver*/
// Here we use the special callback function specific for the Linux Framebuffer Driver
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
// Initialize EVDEV input for the 52pi touchscreen,
// which luckily is supported as an "event input device" by the kernel
evdev_init();
lv_indev_drv_t indev_drv;
indev_drv.read_cb = evdev_read;
static void generalButtonHandler(lv_obj_t * obj, lv_event_t event)
if(event == LV_EVENT_CLICKED)
const char* buttonText = lv_btnm_get_active_btn_text(obj);
if (buttonText == NULL)
fprintf(stderr, "generalButtonHandler: NULL button text!\n");
if (!strcmp(buttonText, "1"))
#ifdef GUI_DEBUGMODE
fprintf(stdout, "Button 1 clicked\n");
} else {
if(!strcmp(buttonText, "2"))
fprintf(stdout, "Button 2 clicked\n");
} else {
if(!strcmp(buttonText, "3"))
fprintf(stdout, "Button 3 clicked\n");
} else {
if(!strcmp(buttonText, "4"))
fprintf(stdout, "Button 4 clicked\n");
} else {
if(!strcmp(buttonText, "5"))
fprintf(stdout, "Button 5 clicked\n");
} else {
// ERROR
fprintf(stdout, "ERROR: unknown button %s pressed\n", buttonText);
static void drawUpperButtons(lv_align_t lAlignment, lv_coord_t lCorrectionX, lv_coord_t lCorrectionY)
lv_obj_t* pUpperButtonMatrix = lv_btnm_create(lv_scr_act(), NULL);
lv_btnm_set_map(pUpperButtonMatrix, upperButtonMatrix_map);
lv_obj_set_size(pUpperButtonMatrix, 800, 80);
lv_obj_align(pUpperButtonMatrix, NULL, lAlignment, lCorrectionX, lCorrectionY);
lv_obj_set_event_cb(pUpperButtonMatrix, generalButtonHandler);
static void drawHomeScreen(void)
// Upper buttons
drawUpperButtons(LV_ALIGN_IN_TOP_MID, 0, 0);
int main(void)
// Initializations
GUIinit();
// Draw main screen
drawHomeScreen();
// Handle LitlevGL tasks (tickless mode)
// Mandatory, otherwise nothing will be displayed
// It allows the callback functions to operate (for example to actually transfer bytes to screen framebuffer)
while(1)
lv_tick_inc(LV_LOOP_INTERVAL_MS);
lv_task_handler();
usleep(LV_LOOP_INTERVAL_MS * 1000UL);
return 0;
The framebuffer device was opened successfully.
800x480, 32bpp
The framebuffer device was mapped to memory successfully.
Button 1 clicked
Button 2 clicked
Button 3 clicked
Button 4 clicked
Button 5 clicked
