I create some projects with lvgl dev7.0 based on commit d108b2e
Normally they can run fine.
However sometime some project can run for a while
(sometime about 10minutes, sometime more than 30 minutes)
, it occurs a runtime-error.
When I check at this runtime-error by decoding the error’s stack .
It shows some messages that the error occurs at
lv_task_handler() at D:\Arduino\libraries\.....\lvgl-dev-7.0\src\lv_misc\
lv_task.c line 181
When I look at lv_task.c
(dev7.0 commit d108b2e ) line 181
L178: time_till_next = LV_NO_TASK_READY;
L179: next = lv_ll_get_head(&LV_GC_ROOT(_lv_task_ll));
L180: while(next) {
L181: if(next->prio != LV_TASK_PRIO_OFF) {
L182: uint32_t delay = lv_task_time_remaining(next);
L183: if(delay < time_till_next)
L184: time_till_next = delay;
L185: }
L186:
L187: next = lv_ll_get_next(&LV_GC_ROOT(_lv_task_ll), next); /*Find the next task*/
L188: }
L189:
L190: already_running = false; /*Release the mutex*/
I dont’ have any idea to solve the task’s error at L181.
How to solve this error that occurs by lv_task_handler() ?
Thank you very much.
It’s probably a memory corruption issue. next
is probably pointing to an invalid task.
If next
is NULL
, it doestn’t go into the while
loop ?
Do you have any idea how to check variable next
next
is probably an invalid value (not NULL
). I suggest you use a debugger and set a breakpoint on the fault handler.
Can you enable logginf of LVGL with TRACE level?
https://docs.lvgl.io/v7/en/html/porting/log.html
You can also add enable LV_USE_ASSERT_MEM_INTEGRITY
. In some places it checks if there is memory corruption.
Can you somehow reduce the object used on the screen to see which one causes the corruption?
