IMXRT1050EVK
V8
lv_animimg_set_src(ui->animimg, (lv_img_dsc_t**) imgs, 30);
lv_animimg_set_duration(ui->animimg, 1000);
lv_animimg_set_repeat_count(ui->animimg, 0);
lv_animimg_start(ui->animimg);
## Screenshot and/or video
typedef struct _lv_anim_t {
void * var; /<Variable to animate*/
lv_anim_exec_xcb_t exec_cb; /< Function to execute to animate*/
lv_anim_start_cb_t start_cb; /< Call it when the animation is starts (considering delay)*/
lv_anim_ready_cb_t ready_cb; /< Call it when the animation is ready*/
lv_anim_get_value_cb_t get_value_cb; /< Get the current value in relative mode*/ #if LV_USE_USER_DATA
void * user_data; /< Custom user data*/ #endif
lv_anim_path_cb_t path_cb; /< Describe the path (curve) of animations*/
int32_t start_value; /< Start value*/
int32_t current_value; /< Current value*/
int32_t end_value; /< End value*/
int32_t time; /< Animation time in ms*/
int32_t act_time; /< Current time in animation. Set to negative to make delay./
uint32_t playback_delay; /**< Wait before play back/
uint32_t playback_time; /< Duration of playback animation*/
uint32_t repeat_delay; /< Wait before repeat*/
uint16_t repeat_cnt; /< Repeat count for the animation*/
uint8_t early_apply : 1; /< 1: Apply start value immediately even is there is delay*/
/*Animation system use these - user shouldn't set*/
uint8_t playback_now : 1; /**< Play back is in progress*/
uint8_t run_round : 1; /**< Indicates the animation has run in this round*/
uint8_t start_cb_called : 1; /**< Indicates that the `start_cb` was already called*/
uint32_t time_orig;
} lv_anim_t;
The “int32_t current_value” is always 0 while the lv_animimg is running.
I have not ever used lv_animimg_xxx(), but in these delay, repeat, etc. functions, it will be set to lv_anim_t. So I think you can use this way to get current.
btw, I am using lvgl ver 7.10.1
I’m not sure if the current of lv_anim_t works in this case.
If your need look like below lv_animimg example
I think you can check current image via pic_count.
Refer lv_animimg_constructor() and index_change() callback in lv_animimg.c
